3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
Scout info for the 6.7L
Old Jul 1, 2009 | 10:45 PM
mega-engr's Avatar
"California Style"
Originally Posted by qzilla
As I mentioned in my PM back to you, I will get you all the info you need.
In the meantime the 06-07 part# is the same as the 07.5-09 trucks! That is one of the reasons we delayed the release so that we could get all the current trucks that would fit into 1 part number!
When are you going to update your website? I don't quite understand how you have it listed as:
"07-09 Dodge 5.9L Cummins"
Are you going to have facts specifically for the 6.7L?
Old Jul 1, 2009 | 10:47 PM
mbmike's Avatar
Scout
So AM I missing something is it out yet ?? for the 6.7???
Old Jul 1, 2009 | 10:50 PM
qzilla's Avatar
Its out, for now, just order the 06-07 part # because it is the same!
We recently hired a new web developer and evidentally some of our new product releases have not gotten out and our website is behind.
The 06-07 part# will do everything I mentioned in this thread!
Old Jul 1, 2009 | 10:54 PM
mega-engr's Avatar
"California Style"
What is "calculated transmission"? Does it have trans temp?
Old Jul 1, 2009 | 11:03 PM
qzilla's Avatar
Yes, it has trans temp.
calculated Transmission Slip % is just that, a calculation we do that measures slippage.
The reason it is calculated is that there is no available data that tell us transmission slip = X %. So what we have to do is take output shaft speed versus rpm, versus gear ratio etc, etc, etc, and then we can tell you how much slippage there is which is all you would get anyway even if it was reported on the data stream.
This can only be done once the converter is locked up and we have a small symbol in the trans slip % window that will tell you if it is locked or not.
Old Jul 1, 2009 | 11:33 PM
mega-engr's Avatar
"California Style"
I see your first post shows trans temp and many others. So, we should go by your first post and not what the website says for the 5.9? Because there is a bit of a difference it seems.
Old Jul 2, 2009 | 11:15 AM
qzilla's Avatar
Go by my post in this thread. The website has not been updated to include the 6.7L stuff and there is a bunch of 6.7L specific stuff!
Also, here are some really, really crummy pictures I took with my cell phone while I was out messing with the truck this morning. It will at least give you an idea of what you will be looking at.
This is just a 4 place display while the truck went into deSoot regen. Also it is a 4 place display but, the small circle icon with a number in it is the current gear just FYI. The Soot icon at the bottom right is how we inform you this is going on instead of wasting a parameter display. Also it does not matter if you are on Display 1 or 2 it will automatically pop up.
This is when it went into deSox regen. The SOX icon is hard to read but it is just above where the SOOT Icon was.
This is the DPF Page, you access this by either pressing up and scrolling through the pages or pressing down from the main display.
This is the Emissions page. You can also select EGR and EGR error and MAF as a parameter in the main display if you want.
Here is the trouble codes page. It also gives you warmup and runtime counts as well as the DTC data.
Old Aug 23, 2009 | 01:11 PM
JThiessen's Avatar
Digging up some old info here - I need to order a Scout system for my brothers 09. The SMS1004 is the right module, how about pillar mount and EGT kits, are those the same also? Larry REALLY needs to get his store website updated with the correct info showing for the 07-09's.....
Old Aug 25, 2009 | 02:04 PM
qzilla's Avatar
SMS1004 is correct. Also the EGT kit and Pillar mount are the same as the 06 trucks!
Old Aug 25, 2009 | 03:11 PM
MOJO1's Avatar
So this will work with the Smarty right? If so this sounds like the best thing out! Does it clear the regen cycle or just let you know the stats? I thought it did if it clears codes. Sounds like a winner to me. Lary when you start selling them I am buying one
qzilla
May 20, 2009 04:06 PM
.boB
19
Feb 18, 2009 06:40 PM
ramlovingvet
Jun 21, 2005 07:17 PM
jrs_dodge_diesel
Feb 15, 2005 06:09 AM
