3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
S67 ME/DPF Delete= Smokes Alot- Anybody?
Old Aug 19, 2009 | 10:34 AM
barefooter's Avatar
Exclamation S67 ME/DPF Delete= Smokes Alot- Anybody?
I have an 07 6.7 3500, auto trans. Have done the DPF delete & Smarty
S67ME14. Followed all the Smarty website guidelines for DPF delete. Great power, better fuel economy, but the thing smokes terribly at a light cruise in the upper gears around 12-1800 Rpm. I mean BADLY. I drive home every night through a residential area around 30-40 MPH & I can barely see behind the truck. No problem if I drive it hard(a little smoke when I get on it hard, but thats to be expected) Belches a bit on the highway at cruise for no explained reason as well but, I just cant drive through my neighbourhood every night like this. Doesnt matter what power setting, the smoke is always the same- Bad. I can can set it back to stock for a short bit before the regen thing happens & it doesnt seem to smoke at all. The new smarty download from July13? was supposed to cure this problem and it hasnt helped at all(and yes I have checked to see that the new version is displayed on the Smarty when I power it up) Anyone else had this problem? I am ready to put the truck back to stock. HELP!
Old Aug 19, 2009 | 11:21 AM
MOJO1's Avatar
I would check all your connections. Make sure you went by the book on the plugs! Go back through and make sure it has to be something simple.
Old Aug 19, 2009 | 01:35 PM
2rowdy's Avatar
How are you running your egr? Deleted, unplugged, stock? And your cooler?
Old Aug 19, 2009 | 01:51 PM
barefooter's Avatar
I have done nothing to the EGR, I am told the ME version does not operate it.
Old Aug 19, 2009 | 02:06 PM
mega-engr's Avatar
"California Style"
Bingo!
You better go back and read their disclaimer and directions!!!
Before you trash you truck!
Old Aug 19, 2009 | 02:50 PM
barefooter's Avatar
I guess this make sense- Was told by the local diesel tech shop here that in the new ME/Revo software the EGR is inoperative & disconnectoion/removal was not required. If they are incorrect, how is the EGR affecting my problem if it is not operating?
Old Aug 19, 2009 | 02:56 PM
MOJO1's Avatar
You need to get it unpluged! Just do it you wont hurt your Truck.
Old Aug 19, 2009 | 03:09 PM
barefooter's Avatar
So should I just unplug it or remove the actuator motor?
Old Aug 19, 2009 | 03:16 PM
mega-engr's Avatar
"California Style"
If you have the "S" software, you don't need to do anything to the EGR. If you have the "ME" as stated, you need to.
Do as the instructions on the site says. If you can't then do as ramble bee said and unplug it as a band-aide.
Old Aug 19, 2009 | 03:17 PM
MOJO1's Avatar
http://www.madselectronics.com/CodeF...EGRDelete.html
This has the write up here just do what it says and you will be fine
Old Aug 24, 2009 | 09:12 PM
LFD2037's Avatar
Well? How did it work out for ya'?
Old Aug 25, 2009 | 09:40 AM
2rowdy's Avatar
Yep follow the mads directions.
Old Aug 25, 2009 | 09:58 AM
barefooter's Avatar
Did the EGR mods the next day- No more smoke. Thanks guys
Old Aug 28, 2009 | 02:03 PM
katoiler's Avatar
What kind of millage improvements are you guys seeing? mine has not changed with or without the egr and delete mods with a bullydog pmt.
Old Aug 31, 2009 | 07:48 AM
Jim W's Avatar
I am using the Smarty 67 with the 14ME program installed, with the ERG delete and a 5" TB exhaust. My mileage is 4 MPG better since I have installed the Smarty 67. When I towed my 5er I have seen a 2 MPG improvement.
Hope this helps?
king cotton
Nov 24, 2010 10:33 PM
d_kuda
15
May 2, 2010 04:28 PM
kyle_truck_pull
Sep 20, 2009 01:02 AM
Red3quarter
Nov 8, 2008 04:11 PM
aron5823
Jun 24, 2008 11:42 PM
