3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
PYRO Temps
Old Jun 28, 2009 | 11:57 PM
4wheeler nut's Avatar
PYRO Temps
I was told and have read that 1450 is a good place to set the warning on gauges. My question is: is this alittle low and conservitive. The 6.7L with the add ons that I have it gets there real quick. I have heared that Al starts to melt at 1600 Degrees. How accurate is this Info.
Old Jul 1, 2009 | 08:46 PM
texbeer2's Avatar
I have seen 1450 a few times but just for a few seconds. My truck will defuel @ 1350-1380. The only times it gets there is towing a 5th wheel @ 75mph and trying to pull a 5% grade or better.
Old Jul 2, 2009 | 06:17 AM
wmonroe's Avatar
Aluminum melts at 1220* if I remember right. In cylinder temps are hotter that what is reading on the egt gauge, but you also have oil jets spraying on the underside of the piston. Myself, I won't sustain over 1200*, but that might be on the conservative side.
Will
Old Jul 10, 2009 | 03:54 PM
kantdrive55's Avatar
DTR Advertiser
1450 is a pretty safe spot to set the defuel. The newer trucks are setup to run much hotter than the old trucks. Stock you can see 1350 on them. Before I put the delete pipe in I saw 1750 when it went into regen for a second.
Old Jul 11, 2009 | 10:58 AM
Lil Dog's Avatar
Regens are around 1350 at the pyro. And actually the in cylinder temps will be less at this point due to the low firing pressure and zero boost coupled with the late 4th injection event when the exhaust valves open.
The Regen cycle is a different animal than under full load. Full load defuel I would still maintain about 1250. Heat and pressure is what will kill the engine components. No load Regens are not that destructive. If you watch the EGT's under REGEN, as soon as you need to load the engine, the EGT backs off until you reduce the load.
BlueDually
Oct 3, 2006 06:58 AM
rockittboy
May 26, 2006 02:02 AM
DmaxEter
Mar 11, 2006 05:03 AM
by2005
May 23, 2005 04:49 PM
cLAYH
Aug 2, 2003 08:09 AM
