Mini Maxx Delete Questions
Well I'm loving my new 6.7L! Powertrain warranty will be up fairly soon so I am starting to plan the deletes.
I'm probably going to go with a Mini Maxx system. It's a bit more than the Smarty, but has all the gauges built into the controller, so that will save a few bucks... But I've got a couple of questions:
1. It says it has the ability to turn off the EGR, without removing it. Is there any good reason to still remove the EGR, besides cleaning up the engine bay?
2. Is the 5" turbo back exhaust going to give any power gains over just swapping the DPF pipe & downtube? Or is it just for the exhaust note? The power gains on the website is the same either way...
Thanks!
S.
Thanks!
S.
if you remove it, you can be positive it will not work...i wouldn't depend on electronics
No warranty, no worries.
Pull about a hundred pounds of junk that should have never been installed off you 6.7 and let it breath man, its suffocating for crying out loud....
You wont regret it.
You wont regret it.
NE frmhnd
May 9, 2014 07:55 PM
millsy
Feb 3, 2013 10:04 PM
folsom_blues
28
Apr 3, 2012 08:54 PM
bggrndodge
Jan 7, 2012 11:03 AM
67guzzler
16
Aug 18, 2010 08:44 PM
