Exhaust brake performance down with Mini Maxx and Delete pipe
I installed my Mini Maxx last Sunday and installed the delete pipe yesterday, so i was able to drive for a week with the DPF in place and check the gauges on the Mini Maxx. My expectations were high, and they were blown out of the water!! My intake temps dropped from eratic pulses up to 150F, down to a nice stable 10-15F above ambient; my mileage is up ~3 mpg, I love the added rumble from the exhaust, and the power (on mild) is amazing!
The only negative I am seeing is that my exhaust brake is a little weaker. Under similar conditions (engine rpm, speed, grade) i am seeing about half the turbo psi with the delete pipe installed. The hold-back force with the delete pipe on is noticeably weaker. Anyone seeing similar results or know why this has happened??
Thats weird, I thought it was just me but I just installed a blackmaxx and new down pipe kit on my '12 3 days ago and I said to my gf when I just about over ran a few intersections that i needed to turn at off the highway 2 or 3 times in a row that the Ebrake seemed weaker but just thought it was me lol. But ya after driving more and more now its getting real noticeable. Lack of back pressure on the exhaust system?
OK, I AM WAY WAY different!!
My E-Brake is way more effective on a full delete truck. Does it have anything to do with my other mods??
Probably not a big deal since I am going with a different turbo but I like it much better on a deleted truck.
I do run the aggressive turbo tuning tune so maybe that is a factor in the E-brake working so good. I never use my brakes till it shuts off at about 1800 rpm.
The exhaust brake on my '07 6.7 is way more aggressive than that on my 2011. I'm not sure why that is. I didn't pull my big trailer until after doing the deletes and MiniMax with the tranny tune so my impression is very subjective. However, the Ebrake feels better than it did stock. That may be in part because I'm in tow haul mode when pulling the trailer, or it could have something to do with the tranny tune software. Either way, it still seems less aggressive than my '07. It did do a wonderful job of keeping me slowed down on a six percent down grade at 23,000 lbs. It could just be that they are bringing in the braking force more slowly. That could account for why it seems less effective in town or slowing down quickly.
I still don't like the integrated trailer brake. It comes on way too slowly. In slick conditions I find myself reaching for the brake controller to manually apply the trailer brakes. Otherwise, I feel the trailer pushing me and risking a jack knife in slick conditions. I may go back to a Prodigy controller since Dodge assures me that the controller is working perfectly.
So here's a thought. I am assuming those of you that are seeing this same issue have no other deletes other than the NOX/DPF? If you still have the EGR in place, like I do, i wonder if it is possible that we are getting some pressure loss by it being "turned off". The turbo is definitely not spooling up as much as when the EGR was active (when running without the delete pipe). I don't have to do an emissions test for another 6 years in this county (in CA), so i might be open to doing the EGR delete if it solves the problem. Just not sure i can trust myself to reinstall it.
Any H&S guys willing to comment on this phenomenon?
it is egr related. The turbo has to work without the egr on a normal basis to make the ''brake'' function. The egr is applieing its own resistance to helping that during its normal function. Kind of how a normal jake works. The engine applies its own pressure with the egr to assist in what the turbo is doing, which is stopping the exaust and creating presure against motion. The egr is taking exhaust from a blocked off point and using it in opposition which in turn creates more engine braking. Im not against the egr as much as I have been. The metalurgy in these engines as opposed to older engines are more than capable of handleing the suspended soot thats in the air and oil that come from exhaust gas recirculation. In non brake form its assiting in adding more air, along with the turbo, to use whats left in the exhaust, in fuel form to create power. There is power to be had from e.g.r. Thats why we see a power loss when its unplugged and why we see less brake when its disabled or unplugged. Although the oil gets black, the engine and the oil are more than designed to accept it.
I'd sure like to hear from H&S about this too. If its a setting that needs cranked up, I'm willing to try it because I need the brake working right with my camper hooked up.
.... Im not against the egr as much as I have been. ... In non brake form its assiting in adding more air, along with the turbo, to use whats left in the exhaust, in fuel form to create power. There is power to be had from e.g.r. Thats why we see a power loss when its unplugged ...
The way I understand the EGR is the EGR opens to allow exhaust gas into the intake and at the same time the throttle valve restricts the air coming from the compressor section of the turbo. This in turn with the extra injection event increases exhaust gas temperature to regenerate the DPF. While this is going on during the regeneration cycle ONLY, makes everything including the pressure/temp sensor (formerly MAP and IAT) in the intake dirty.
If the EGR only comes into play during the regeneration cycle it can't possibly be a factor.
What I'm not sure of is does the throttle valve normally restrict the airflow during exhaust brake operation, before deletes?
