3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
gauges
Old Mar 5, 2010 | 01:08 AM
mega-engr's Avatar
"California Style"
There is a huge list of things that it monitors. Too many for me... I just go with the basics (EGT, BOOST, TRANS TEMP, FUEL PRESSURE). The truck has sensors to bring trans temp data to the trucks (for safety purposes I suppose) computer and this is grabbed by the Insight from the OBD II port.
EGT probe is the only item needing to be installed. I got the guage pillar mount as well.
The S67ME and Insight with EGT is about all I should ever need.
Old Mar 5, 2010 | 05:18 AM
Blake Clark's Avatar
Mega is right. EGT probe is only install. All other data is collected through the ECM via the OBDII port.
Old Mar 6, 2010 | 04:05 PM
CORam2's Avatar
So can the Edge Insight measure turbo boost and fuel pressure without any additional sensors or add-ons?
Old Mar 6, 2010 | 06:17 PM
Txwinghunter's Avatar
I installed the insight on my 09. It was very simple. The EGT probe is the only thing that you have to install. All the other data is recieved off of the ECM through the OBD II port. There is no other wiring to do. Simply plug it in and select what you want to monitor on the display. I also bought the mounting box that goes on the dash. Very simple, just follow the directions. It monitors just about anything. Check out this link all the info is there.
http://www.rollinsmokediesel.com/pd-...uple-probe.cfm
Yup, all the other parameters are collected through the OBDII port.
Old Mar 6, 2010 | 07:38 PM
CORam2's Avatar
Great! Do you know which fuel pressures it monitors? Lift pump pressure, rail pressure?
Old Mar 6, 2010 | 07:46 PM
99% sure its rail pressure.
Old Mar 6, 2010 | 07:56 PM
CORam2's Avatar
Ok thanks.
End Hijack..........
Kman9090
29
Dec 6, 2007 06:43 PM
coontz0473
17
Sep 22, 2006 03:52 PM
Duckman1993
Sep 12, 2006 07:50 PM
estesbubba
Jul 18, 2006 04:35 PM
AggiePhil
Jan 30, 2005 01:15 PM
