First emissions test with deletes and Smarty Jr., which setting to use?
"California Style"
Well, I guess that seals the deal for me. I'll just put the entire exhaust back on each year and get it tested (visually). What a joke.
My wife said they took a really good look, three different guys all conversing in secret and scratching their heads. Made her open the hood three times, crawled under the truck, etc. When told her about the Cat she responded "Do you think it could have fallen off or something?" LOL. Their response was for us to check with the mechanic who installed the exhaust because he may have kept the Cat and then sold it to someone else. LOL
They are going to love it when she shows back up with the equipment magically installed again.
ben
ben
Mega, When you put everything back for the inspection, does that include the actuator valve in the EGR system or is it still turned off (tuner) when you take it in?
Also, one other annoying question for you and Blake, I am going to be doing a mix of the 2 delete methods and am assuming, since this is a daily driver which will never see a race, I will still have to have a tuner.... if for nothing else, just to turn off the EGR & DPF functions. The EFI Live (Beta for Cummins) looks very promising but is probably way more tuner than I'll ever need; so, is the Smarty Jr (ME) going to be sufficient to turn off the EGR & DPF system, help or hurt efficiency, and do I really need the added guages for running the 1st & 2nd programs? I do some heavy hauling (hay, cattle, equipment) but not on a consistent basis. Just wanted to get your opinions on minimal mods with deletes.
Thanks, that gives me the starting point I am looking for not too pricey but gets the job done well. I've always been a 'stock' type guy in the past but who knows where it will lead, may end up getting up to speed with the rest of you!
Final update
Spent the morning and part of the afternoon yesterday putting the stock exhaust back on my truck. For those who don't know, I had done the full deletes, so that means turbo back exhaust. Foot notes for the install require you lower the cross member for the transmission in order to get the stock down pipe and cat out. It was a pain in the *** when removing the pipe, but even more so when reinstalling. Lucky for me a friend came over just in the nick of time to help me.
Given this, my thought was to recommend to anyone that has to do annual emissions tests to perhaps consider a cat back exhaust instead. The difference probably would have been 4 hours saved in the exchange.
Well, I passed the emissions test and now the visual inspection. Funny thing is the manager at the inspection station looked at the DPF and NOX filters using the mirror, then made the comment to me "Wow, they put two cats on this?" I partially corrected him and said one is the DPF. What a joke and waste of my time. I mean, really, if I passed the emissions test with all of the emissions garbage removed then what is the point of requiring me to reinstall the cat? Especially if one assumes that I'm just going to remove it again later that day. Stupid!
Another observation/hint -- Before you install your cool new aftermarket exhaust, cut the nipple end of the hanger for the down pipe off. It will make installing and removing the down pipe a ton easier and won't affect the install at all.
ben
ben
ramdiesel23
08-29-2012 05:51 AM
sevobuck
12-18-2011 09:48 AM
BOB DIEZEL
03-23-2009 07:45 PM
TNLoneWolf
10-06-2007 09:59 AM
