Buying NEW
Buying NEW
Hello all, Been out of the Seen for some time. I sold out last year been waiting for everything to get lined out on the 6.7s. Do they have the DPF delete kit done? You guys know what im talking about I want to CRANK IT UP! All the info would be GREAT THNAKS J,C,
Hey Brother,
Check into the Smarty setup, from what I understand, you can use any 07.5 and down after market exhaust and the Smarty will handle all of the electronics part of it, EGR off, regen off, etc, with no need for the exhaust temp simulators or O2 sensor bungs.
I have the H&S Perfomance delete kit, and the Edge Juice with attitude, and while it does work good, is not code free.
Good Luck
Good Luck
Thanks like I said I Sold out a Year ago and have been waiting for the day I could do a 6.7. I loved my 5.9 but want to step it up a notchnI miss the Big Dodge driving a Jeep JK Just dont cut it when i have drove Diesels sents early 90s. I will do the back ground checking on here. I am use to the 5.9 guys. You 6.7 guys dont seem to give up any info on the mods. I know it is because i am geting back in the posting thing.
Thanks blake.clarkfor answering a true Diesel Brother.
Oh and one more thing, beware of the new trucks, FOR NOW, there is a TSB out that if you program the ECM is lock out and voids the warranty. Im sure that the folks at the aftermarket companys are burning the midnight oil to combat this, and Im sure that just as with anything else electronic it will have a workaround. Just some advice to do a good bit or research before you run out and buy. Let the naysayers blow their hot air.
Electronic wise, look how long Apple and At&t was able to get that under wraps.
Oh and the build dates on the lot are suprising. I got mine 3 weeks agoand it was built in October or November. I was kinda suprised when I saw that. No wonder deals are so good right now.
I do believe that March 09 is the cutoff...
check here for the entire tsb
https://www.dieseltruckresource.com/...3&d=1239905074
Should be able to find what your looking for in a truck with a build date prior to that, I know when I got my 08 in Feb of 08 it had a build date of about six months prior.
Hope this helps.
Hope this helps.
burlhall
31
11-13-2004 09:11 PM
bish777
07-15-2003 10:50 PM
