3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
6.7 starting
Old Apr 3, 2009 | 09:23 PM
Nigel R's Avatar
6.7 starting
my 6.7 cranks alot before starting when restarting warm? No codes showing.
Old Apr 3, 2009 | 10:05 PM
Lil Dog's Avatar
Just started doing this or has always done it?
Old Apr 4, 2009 | 08:04 AM
Harvie's Avatar
Turn the key to "on" and leave it for 30-45 sec before you try cranking.
My old one would fire right up the 9 6.7 cranks longer but much less when leaving the key on for 30-45 sec.
Old Apr 4, 2009 | 11:01 AM
Scotty's Avatar
Top's Younger Twin
Other then when I have the wait to start light on, I start asap. 116,000 miles and have not experienced long cranks. It fires within a second or two...never really timed it...seems pretty much fired up instantly.
However, a friend of mine had a similar situation with a very new [less then 5K miles] truck. Just for the heck of it he changed out his fuel filter and it starts quick now. maybe some poor fuel from the factory? Who knows.
Scotty
Old Apr 22, 2009 | 12:15 PM
hiperffun's Avatar
My truck now has 11,000 miles and has always turned over several times
before starting.
Old Apr 23, 2009 | 01:02 AM
xb9rumble's Avatar
Mine will fire right up half the time and will crank for a couple seconds the rest. Only 9k miles and it has been doing it for ~3k miles
Old Apr 26, 2009 | 09:52 AM
DarkDesertCTD's Avatar
When my wait to start light is on I wait and then it fires right up. when it's not on I start it and it cranks once and the second time it starts. 08 with just under 5K miles
Old Apr 26, 2009 | 05:10 PM
Nigel R's Avatar
starting 6.7 warm
thanks for replies ,it is better if I wait afew seconds before hitting the starter.Cheers Nigel
Old Apr 26, 2009 | 08:41 PM
Quick's Avatar
mine too - longer when warm. fires right up when cold
Old Apr 28, 2009 | 12:11 PM
boatpuller's Avatar
my 6.7 seems like it cranks a little longer before it fires then my 5.9 did.no biggie,just something i noticed.
Old May 5, 2009 | 12:47 AM
rbmedic75's Avatar
check to see if you need an updated flash from dodge I know but there was a TSB about extended cranking times i was also said to pick up 3 MPG or so with just the updated flash. Most have to be plugged into the scan tool to find out which flash they have but a good dealer ship will do this under warranty if you tell them your having the extended crank times. PS eventually the check engine light will come on but i dont remember the code of hand
Old May 21, 2009 | 10:45 AM
jthorpe's Avatar
DTR Founder
I'd be curious in hearing more information about this. If there is an answer, I'd like to post it on the wiki and in the forum.
Old May 21, 2009 | 09:53 PM
ratlratl's Avatar
MMMmmmm.... Grits!!
I always wait for the 5 dings before hitting the start button. Of course the wait to start in the winter, but any other time I just wait for the dings. Don't know why they are there but must be something.
Chris
fourthandgoal
88
Dec 27, 2011 05:39 AM
RED99CTD
Apr 20, 2011 08:08 AM
abc4yew
Mar 15, 2007 11:55 PM
Commatoze
Sep 3, 2006 02:30 PM
admin
16
Aug 17, 2003 10:07 AM
