6.7 Missing
6.7 Missing
Got A 07 Dually 6.7 With Standard Trans. Every Once In A While The Thing Will Miss Like If You Pull Up To A Red Light You Can Feel It Does Any One Have A Clue As To What May Be Causing This
Post in the 2007 and up forum. But from what I have read one guy had this issue due to a bad wiring harness for the injectors. Said it was the same as yours but over time it started missing regularly and logged a code for the miss.
