xzt works finally, first impressions
Old Nov 9, 2006 | 07:32 PM
rockhound's Avatar
I received the new harness from qzilla last night. The harness that came with my used (used but reflashed) xzt was shorted or missing a connection somewhere and thus throwing codes.
Finally had the chance to drive the truck with the module installed and working as advertised.
The truck runs like a raped ape. A lot of my buddies are running this stacked on top of that and putting gobs of power to the ground,
first impressions of this box is the truck has plenty of power, i don't think its as fast off the line as some race boxes but it pulls hard through all gears. Merging onto the interstate this morning i went from 60 to 80 so fast i couldn't believe it
i want it to be reliable and tow my 34 ft, 5er more efficiently so idon't want to stack or give it so much power that it grenades on me, i will tow it early next week and see what it can do
So far very happy with Quadzilla's product.
Old Nov 9, 2006 | 10:20 PM
bigwheels94's Avatar
Congrats on getting your box up,& running.I'm sure you will love the towing power the XZT gives.I was able to go over mountain passes in O/D @ 75mph. running only 1200* EGT.& I had more if I needed it.That was running 11,000#GVW scale weight.
Old Nov 10, 2006 | 05:36 AM
Hunter11's Avatar
I bought my XZT for the same reason. I wanted a little extra power and mileage plus something that would not scatter my transmission down the highway while towing our 5th wheel.
Old Nov 10, 2006 | 08:53 PM
rockhound's Avatar
well it also makes the truck haul a..
Old Nov 11, 2006 | 06:19 AM
Dodgezilla's Avatar
I guess it works well with the Rokktech too eh Rockhound?
Old Nov 11, 2006 | 10:00 AM
Dynocon's Avatar
Still looking to purchase a box, leaning towrds the Quad race box.
When you say XZT do you mean the race box, 100 HP box or the 65 box?
With comperable driving conditions and styles what have you noticed as far as MPG gaines?
Old Nov 11, 2006 | 10:34 AM
BigDave12768's Avatar
He got the Dxzt2. It's 65 hp box
Old Nov 11, 2006 | 10:39 AM
rockhound's Avatar
yes its the 65 hp 165 lb ft box
i haven't had it working long enough to calculte mileage gains as yet
I topped off last night and will calcualte a normal driving situation this next couple of days, the gain will have to be my guide as i drive from denver and climb the colorado mountains to home everyday, the 7 % grades will kill your fuel mileage
dodgezilla,
i actually backed my rokktech back to stock for now, i may bump it back i may not, do you see gains in mileage using the timing sensor with the box?
Old Nov 11, 2006 | 10:44 AM
nelrod's Avatar
Mine xzt tow box - truck went from 13.5-15mpg to 18.25mpg and hauls Male donkey too. Got a 140 hp race box to go on it though, since power bug bit me, got the FFFEEEEVVVVEERR.
Old Nov 11, 2006 | 02:28 PM
tslewisz's Avatar
I can't really answer your Q about the mileage, but my Rokktech is fully advanced and I have no issues with my 100HP Quad box. I mostly run it at 60HP, which I think is pretty much the same as your XZT.
Old Nov 11, 2006 | 08:04 PM
Dynocon's Avatar
Since the race box has several settings, it sounds like it is the same as the 65 and 100 HP boxes, plus a little.
I want to purchase one, but do not want to pay a few hundred for a 65HP box, only to wish for more.
I am easy on the truck, very little towing and hot rodding, mostly Interstate. Would the race box kill the truck?
Old Nov 11, 2006 | 09:23 PM
rockhound's Avatar
if you into the racing serious hot rodding thing go for whatever you want
for me the 65 hp 165 lb ft was perfect for me, consider this
my buddy just removed his juice/attitude off his 04, nearly an 800 dollar box
when he was all said and done the dyno numbers from edge claim a max lb ft of 775 peak, the same as my truck with the xzt i bought used for $175.00
and i don't have to worry about tearing up my truck,
the thing pulls hard through all the gears and goes faster than i can safely go on the street anyway
Old Nov 15, 2006 | 09:02 PM
nelrod's Avatar
Dynocon, I will sell you my xzt that has been on for less than 2 tanks.It does great and got me 18.25 mpg ( much better than before XZT) I just put race box in. Its just however much power you want. After having extra 60 or so, I wanted 140 or whatever it is.
Old Nov 15, 2006 | 09:35 PM
rockhound's Avatar
hand calculated mileage for the last two tanks
13.6 mpg, up about .5 mpg, pulled the 5er up from denver for about 40 miles mixed in there somewhere
that is about all i see on a daily basis as i do climb the mountains every night for 35 miles home, several long 6-7% grades, at least 2-3% all the way home, i can't say i have been keeping my foot out of it either, ran at least 70 mph+ for the last 3-4 nights
i haven't had the chance to just get out and just run down the higway
i try and test it agin without the towing for a day or so
TORQUE
31
Aug 3, 2005 12:05 PM
BigBlueDodge
198
Jul 1, 2005 04:25 AM
BigBlackDodge
Jun 13, 2004 08:28 AM
NDanecker
16
Apr 23, 2004 06:48 AM
Cowhand
Jan 12, 2004 08:54 PM
