XM Radio Install
XM Radio Install
Has anyone had the XM Commander (for XM Radio) installed in a 03/04 Quad Cab? If so, PROS/CONS and provide pics of the face unit and antenna where you had it mounted...
thanks
thanks
I dont have that particular model, I have the Delphi XM Roady. Its mounted to one side of the storage compartment below the radio. Looks pretty good and I still get to use about half of the storage compartment. The antenna goes out through the 3rd brake light. And I assume the wire is routed inbetween the headliner. BestBuy installed it and did a good job, except for the light leaking when it rains because of the antenna cable. Need to have them fix that ASAP.
I could take pictures of it later if you want.
pronstar
18
08-06-2009 09:49 PM
rico334
14
01-10-2006 07:25 PM
RamRat
07-22-2005 08:04 AM
