Would using control arms from a 6" on a 4" kit be ok?
Old Dec 2, 2007 | 11:18 PM
VisionxOrb's Avatar
I know I know run Thuren, Kore, Carli or Lorenz system. I was going to get a complete custom 4" setup from don a few months back till a puppy of mine came down with parvo and his hospital stay zaped my truck upgrade fund.
Now I need to get new tires really soon and dont want to have to get tires twice so I want to cheaply get my truck up 4" and replace the springs and shocks with dons stuff at a later date since I already have some parts.
I already have a track bar relocation bracket and pitman arm for a 4" kit from when I was going to have done build me a set up plus I have control arms from a 6" tuff country kit that I got over a year ago.
Don told me he thought the arms should work, im just nervious never hearing else run a similar setup so I wanted to get more opinions and see if I can get a "will work" or "your death wish". If they do work then i wouldnt need much other parts to finish the lift ( probably get the 4.5" tuffcountry pucks till i got dons springs ) plus being a little longer I would have more room to run less backspacing and get rims I like.
The control arms measure approx 18 5/8 for the upper arm and 20 1/16 for the lower arm.
Old Dec 2, 2007 | 11:22 PM
06CTDforAU's Avatar
Don told me he thought the arms should, im just nervious never hearing else run a similar setup so I wanted to get more opinions and see if I can get a "will work" or "your death wish". If they do work then i wouldnt need much other parts to finish the lift ( probably get the 4.5" tuffcountry pucks till i got dons springs ) plus being a little longer I would have more room to run less backspacing and get rims I like.
I don't see where it'll matter too much. It'll just push your axle a little farther forward letting you run rims with a negative offset. Be careful though..... if you go too long on the arms with too much of a negative offset you can also hit the front bumper.
Old Dec 2, 2007 | 11:24 PM
VisionxOrb's Avatar
well its an 06 and that part of the bumper is mostly plastic, I have no problems trimming that with my cutoff wheel. I want to make sure that I wont have a problem setting castor or any steering or track bar hitting.
Old Dec 3, 2007 | 04:43 AM
JbD's Avatar
JbD
Your trackbar drop bracket may hit the lower coil bucket over good bumps. A little trimming and/or bumpstops should fix it.
Old Dec 3, 2007 | 11:21 AM
bob4x4's Avatar
The sway bar end links may also hit the coil springs
Bob
Old Dec 3, 2007 | 03:37 PM
VisionxOrb's Avatar
Bob
do you know if there is a way around this?
Old Dec 3, 2007 | 03:56 PM
bob4x4's Avatar
Buy the correct length arms
Bob
Old Dec 3, 2007 | 08:51 PM
VisionxOrb's Avatar
Bob
Well besides that, what about those splined torsen bar swaybar setups that kore and don have ( atleast on the picture of his truck ). Dont know if they change the positioning any.
Old Dec 3, 2007 | 09:23 PM
firemansdiesel's Avatar
If you are thinking of dropping money on a swaybar set up. Why don't you order adj. control arms from Thuren? Cost just as much as the swaybar setup if not cheaper. Then you will not have a problem and one more step closer on your build up.
If you want to know the price (I ordred them a couple of weeks ago) PM me.
Old Dec 3, 2007 | 09:27 PM
Lsufan78's Avatar
don't run a sway bar...i haven't run mine in over a year.
Old Dec 3, 2007 | 09:44 PM
Muddin_dude06's Avatar
What I would do is go buy some used tires at a local tire shop for super cheap. I went and got some on my backup truck today and they had a set of 305 BFG Mud Terrains for 17" wheels with 60% tread for $120 mounted and balanced... If I had 17's I woulda bought them but I am pimpin' 16's HAHA
Old Dec 4, 2007 | 04:03 PM
chipmonk's Avatar
pushing your axle out too far can result in handling issues like bump steer. i would try to get adjustable arms or ones from a 4" kit.
PhillyB
Oct 5, 2011 09:22 PM
Tacomaman87
Aug 27, 2009 01:01 AM
smokinram99
Nov 18, 2008 09:02 PM
Captain
Feb 12, 2008 02:18 PM
wcbcruzer
Aug 2, 2006 12:54 PM
