Will Smarty enable high idle function on ECM?
Old Sep 24, 2008 | 11:46 AM
  #31
Dwitt0187's Avatar
Originally Posted by MikeyB
Strange, but the '03 with manual transmissions doesn't have the high idle feature.
MikeyB
that is what i was getting ready to ask is there anyway for an 03 to have the high idle option on a manual trans??
Old Sep 24, 2008 | 11:58 AM
  #32
MikeyB's Avatar
I have seen an aftermarket electronic kit that ties into the APPS. Or can be done mechanically the el cheapo way with a choke cable.
MikeyB
Old Sep 24, 2008 | 10:53 PM
  #33
NYTCTD's Avatar
It isn't just the manuals, early '03 autos don't have high idle either. I talked to Bob W about it and the SMJ can't enable it because it simply isn't there.
Old Sep 25, 2008 | 06:45 AM
  #34
jrussell's Avatar
Sounds like Stainless has more problems than just a programmer bug.
Old Sep 25, 2008 | 09:57 AM
  #35
matego's Avatar
madhat's monkey boy...
Here is a pic I made and had it posted before. It shows you where to hook up the wire. If anyone needs the little harness, we usually stock them at work and I will check this evening to see how the inventory looks.
Old Sep 25, 2008 | 07:52 PM
  #36
homewrecker's Avatar
Attachment 24044
Is the back side of the connector(like pictured) the side with the wires going into it?Gonna put mine on tomorrow weather permitting.
Old Sep 25, 2008 | 08:02 PM
  #37
matego's Avatar
If you look at the connector it has the numbers on it just like the pic. That way its not confusing as to whether you are looking at the back side of the connector or the front.
Old Sep 25, 2008 | 08:04 PM
  #38
RRC's Avatar
RRC
Jr. enabled my high idle...
Old Sep 25, 2008 | 08:06 PM
  #39
StealthDiesel's Avatar
Yes, rear most connector B. Pin 22.
Unbolt connector B from the PCM. I didn't even disconnect the trucks batteries.
There should be no wires in pin 22, just a plastic plug. Push out the plastic plug and insert the pigtail.
It will click in place & give it a tug to make sure it is seated correctly. Re-insert connector B and tighten the bolt.
Prior to doing this I added another 6 inches of wire to the pigtail and attached an eyelet to the end.
I removed one of the PCM attaching bolts & inserted the eyelet in it for the ground.
It should work..
...Joe
Old Sep 25, 2008 | 08:43 PM
  #40
ohyeahfriday's Avatar
Originally Posted by PRO-NRA
It is the one towards the rear of the engine close to the firewall. I do have a written instructions with pics saved. I can email it to anyone that needs it.
Care to shoot them my way? ohyeahfriday@gmail.com
Much appreciated,
Pat
atch
Nov 1, 2010 02:45 PM
dodgezilla04
Jan 12, 2007 01:01 PM
6 2 Carl
Sep 22, 2006 01:00 PM
BobT2004
Jan 18, 2005 04:32 PM
