will 285/70/17 tires change MPG alot??
Old Dec 27, 2006 | 03:40 PM
CTDowerTN's Avatar
iam thinkin of gettin some BFG AT 285/70/17 if it wont change my MPG alot, if it does, i'll just settle for the 265's....
Old Dec 27, 2006 | 03:41 PM
4x4dually's Avatar
I don't know about 17" tires on a 3rd gen, but I went from 285's on my '02 and dropped 3-4 mpg. That stinks!
Old Dec 27, 2006 | 05:34 PM
John Faughn's Avatar
Taller is better for millage .
Wider is worse for millage .
Old Dec 27, 2006 | 08:32 PM
gsbrockman's Avatar
The LT285/70R17's are probably the more popular choice for replacement tires......a tad taller than stock without alot of power / mpg robbing properties. I run them on my '03 and have been pleased with the upgrade. The A/T style tread designs should also be more fuel efficient than the M/T style I run in the Cooper Discoverer STT's.
Greg
Attached Thumbnails will 285/70/17 tires change MPG alot??-dcp02002.jpg
Old Dec 27, 2006 | 10:37 PM
Dalbery's Avatar
I switched to Cooper Discoverer STT's in 285's and lost 2-3 mpg's. I think if you don't run as agressive of a tread pattern you won't be hurt as much as me.
D
Old Dec 27, 2006 | 10:57 PM
3500lly's Avatar
I put some 285's on my old chevy 3/4 ton 8.1 L and lost 3-4 mpg, sounds like it wont be as much on these trucks though, and I wouldnt think that it would be
Old Dec 27, 2006 | 11:27 PM
Mariner 250's Avatar
Dont forget to adjust mileage from odometer reading because of taller tire before figuring mileage. Easiest way is to use a gps or compare mile markers on interstate to odometer.
Old Dec 27, 2006 | 11:30 PM
surfram's Avatar
After having the pinion factor reset to 634 for the 285s, I lost maybe .5-1mpg. I averaged 20.2 per the overhead on a 340 mile trip last weekend. My truck is stock.
Old Dec 27, 2006 | 11:50 PM
Rocky5.9's Avatar
I did a tire calc seach. What is the other numbers for your stock tire? If you are going from 265 70 17 to 285 70 17, it is going from a 32x10.4 to a 33x11.2 and you lose a little over 3%. If you usually get 20mpg you would lose .6 mpg.
pete97
Mar 6, 2012 04:25 PM
lawnman757
Jan 10, 2008 12:45 PM
CTDowerTN
16
Feb 9, 2007 07:45 PM
wood_n_soldier
Jan 16, 2007 12:52 PM
sakisaki400
23
Dec 31, 2006 10:17 PM
