My new fuel mix got me 21.5 for the first time
Old Dec 19, 2006 | 01:58 AM
BigDave12768's Avatar
I have been doing my own little test for about 2 months. I do the same 85 mile R/t about once a week. This average was based on me reseting the overhead while on the downramp to the highway. It is 83 miles of highway and 2 miles off highway with no lights. Some hills are involved. I also set the cruise at 69 on I95 (35miles) and drove 55-60 no cruise on I93 (7 miles). So here are my findings. But they maybe flawed. I took my truck to the dealer and they adjusted the tranny. But I do not think it should matter. All of these were down with a new full tank of fuel for each new mixture
Power Service --19.2
Power Service w/MM 19.5
Marvel Mystery 18.8
FPPF Total Power 19.7
Power Service & FPPF 21.5
I have found my new mix tonight. I put in about 8 ounces of each. Truck ran quieter and smoother. KNow I know traffic and other things play into my studies. But I usually only run down at night. So the return is very light traffic and the way down is always around 8-9 pm. Plus my new found mileage was after a dealer visit that adjusted tranny.
Old Dec 19, 2006 | 02:51 AM
SSminnow's Avatar
Marvel Mystery 18.8
You add 8 ounces of each what???? The Power Service and FPPF? And are these mileage claims based off of one 80+ mile trip??? If so, I can tell you that today my truck got 20.4 MPG with nothing more than driving 55-60 MPH because of extreme Fog and rain, and I have owned my truck for over a year and put almost 40K on it (122K and counting) and I normally get 17-18 MPG on the highway driving normal (70-75MPH)
Old Dec 19, 2006 | 04:52 AM
AlCorr's Avatar
What is FPPF???
Old Dec 19, 2006 | 05:49 AM
dodge2005's Avatar
Marvel Mystery 18.8
I really would love to know what you get with more miles on a tank of fuel. My best was 21.8 mpg and 799.2 miles on 1 tank of fuel just using Power Service also driving 65mph with cruise. Please let me know your results. You might be on to something if you get that kind of mileage with your new concocksion.
Old Dec 19, 2006 | 06:01 AM
toyhaulersdream's Avatar
will check back to see if you can repeat this type of performance- really hope you can- will be checking back- cool data Bud- right now I am running a simuliar mix- 10oz Lucus / 10oz PS mix- getting right at 19-19.5 mpg- keep in mind truck only 1500 miles on it
Old Dec 19, 2006 | 08:54 AM
mikitaclan's Avatar
I wound up with 21 mpg using power service and driving 50 mph because of snow (I was in 4wd). Slow is better!!!
Old Dec 19, 2006 | 08:58 AM
BlackSheep5's Avatar
Originally Posted by AlCorr
What is FPPF???
ya what is FPPF?
Old Dec 19, 2006 | 09:48 AM
AlCorr's Avatar
Ya, what is "FPPF"?
Old Dec 19, 2006 | 09:57 AM
2003Ram's Avatar
Another additive.
http://www.fppf.com/
Old Dec 19, 2006 | 11:07 AM
Don M's Avatar
DTR Advertiser
The Ethyl Corporation strikes again!!
Although it is manufactured by many chemical companies under license, the Ethyl corp developed it. Remember the old days of "Ethyl leaded gas?" That was one of their best. Now we have the 2 ethyl-hexyl nitrate additive for Diesel engines.
Many of the secondary additive companies like FPPF use 2-ethyl-hexyl nitrate in their blends. 2EHN has been helping mileage in Diesel engines for years. It raises the cetane level and helps the autoignition time ( shortens it ) when conditions in the cylinder are cooler and less dense. Examples are empty trucks, slow engine speeds, etc. Under heavy boost and at higher RPM ranges, the additive effects are much less, because the heat available for autoignition is higher.
Higher mileage and easier starting is the result.
Don~
Old Dec 19, 2006 | 12:35 PM
JohnInNH's Avatar
Not the easiest to find... Trying to get a case or 2 for my Co. Got the regional rep calling me ... Good stuff ... IMHO.
Old Dec 19, 2006 | 12:56 PM
SS our trucks are worlds apart. I have a 4x4 with the 4.10 and the 600 series motor. Yours is an 03 2wd 6spd tough to compare the 2 when it comes to fuel mileage
Old Dec 19, 2006 | 01:02 PM
I agree it is not sold at the major parts stores. I get mine at Fleetpride. The guys tells me they also sell it in the 55 gallon drum.
http://www.fleetpride.com/fp_p/index.html
Old Dec 19, 2006 | 08:04 PM
gus's 03's Avatar
im soooo glad im not plagued by a 600 motor...
oh , did i mention im averaging mid 20's consistantly with stop and go trafic? yep .. 4x4, yep, heavy 35's, yep, 4.10's yep...
Old Dec 19, 2006 | 09:58 PM
Cowboy 6's Avatar
Marvel Mystery 18.8
Since you have all this data on one truck, could you/would you possibly try out some Howes? I would love to see what you get with that.
