Wierd Situation!
Old Jan 5, 2009 | 08:14 PM
White97GTVert's Avatar
I still think you should change to software 5 and try that. With the bigger injectors you don't need to run the Smarty on 9 with a stock cp3.
On my truck, with a 62/71/13ss turbo at the time, and Flux 2's, a stage 2 pump, and Smarty TNT on level 3 I made 521 hp on a mustang dyno. That was timing 2, torque 2, and rail pressure 2.
Maxing out your tuner settings is not the way to go. Start lower, and slowly progress upward until you stop seeing performance gains. Although tuning your truck without a rail gauge is a pain.
Old Jan 5, 2009 | 08:18 PM
zack birge's Avatar
I backed it down to sw9 and so far just crusing around seems to be alot better. Now I will probably tow again this coming weekend to see if it helps with that!
Old Jan 5, 2009 | 08:19 PM
zack birge's Avatar
I mean sw7 my bad im tired!
Old Jan 6, 2009 | 03:21 AM
Ok cool. Try it out towing and let us know. Hopefully all is good with it!
Old Jan 6, 2009 | 06:48 AM
Brian Lent's Avatar
I also have to run my stock cp3 on sw 5. Dynoed better on 5 than on 7 or 9. I am not familiar with your sticks but they are probably larger than mine so try 5 or 3 TNT. I tow 16k on 1 and with a single keep egts in check. Your rig will be awesome when you get it tuned in. That is one thing good about being a broke white boy is i usually only put one mod on at a time and is easier to pinpoint issuse.
Old Jan 6, 2009 | 06:51 AM
zack birge's Avatar
Yea lol thats true! Ill let yal know this weekend when I get to tow again. Thanks for all the help!
Old Jan 6, 2009 | 09:35 AM
jaredb900rr's Avatar
Could any of the Commander settings be causing it to defuel?
Old Jan 6, 2009 | 09:56 AM
zack birge's Avatar
I don't think so because the is no module it just displays readings I believe.
MCMLV
Dec 14, 2004 01:28 PM
Mostwanted
Sep 12, 2003 09:58 PM
Aug 14, 2003 01:53 PM
CTD99
Jun 14, 2003 03:00 PM
