tire situation
Old Sep 10, 2003 | 08:53 PM
Mostwanted's Avatar
tire situation
I need front tires. I want to go to from my 215's to 235's. I can only afford the 2 righ now, so can I run 235's on my 2 wheel drive truck till I can afford the rest?
Old Sep 10, 2003 | 09:02 PM
scottrod's Avatar
Re:tire situation
As long as they fit the rims, it won't hurt.
I run 2 different sizes on my Chevy 2wd.
Old Sep 10, 2003 | 09:12 PM
Mexstan's Avatar
Re:tire situation
I am sure everybody on this forum knows this so forgive me if I am preaching to the choir. NEVER run different tire sizes on the same axle. I have seen this more than once, but of course never on a Dodge.
Old Sep 10, 2003 | 09:23 PM
scottrod's Avatar
Re:tire situation
I am assuming he meant both fronts or both rears
I can't imagine someone would run different sizes on the same axle, would they ???
Old Sep 10, 2003 | 09:53 PM
Mostwanted's Avatar
Re:tire situation
I said front's didn't I??
Old Sep 10, 2003 | 09:59 PM
scottrod's Avatar
Re:tire situation
[quote author=MOSTWANTED link=board=10;threadid=19547;start=0#msg183362 date=1063248826]
[/quote]
Yep you did. And I would'nt be scared to do it ;D.
Old Sep 10, 2003 | 10:24 PM
jfpointer's Avatar
Re:tire situation
[/quote]
Those are usually on the same axle, as far as I know.
Old Sep 11, 2003 | 04:01 PM
dsldan's Avatar
Re:tire situation
Dont do it if you have full ABS>>>>>>>>>>>&gt ;>>>>>>>>
Otherwise no problemo.
Old Sep 11, 2003 | 07:29 PM
Mostwanted's Avatar
Re:tire situation
Why?
Old Sep 11, 2003 | 07:45 PM
Dieselbuilder's Avatar
Re:tire situation
Just run the new tires on the back 235 on the outside 215 on the inside You will always be running a spare
Old Sep 11, 2003 | 08:13 PM
jfpointer's Avatar
Re:tire situation
[quote author=MOSTWANTED link=board=10;threadid=19547;start=0#msg183722 date=1063326556]
Why?
[/quote]
It'll screw up the way the ABS works to have different sizes. It has to make certain assumptions and/or calculations based on speed-sensor readings, etc.
Old Sep 11, 2003 | 08:38 PM
Mostwanted's Avatar
Re:tire situation
so what will happen?
Old Sep 11, 2003 | 10:33 PM
dsldan's Avatar
Re:tire situation
the ABs could work all the time or not at all......
Old Sep 12, 2003 | 07:12 PM
spots's Avatar
Re:tire situation
The abs will detect different rotation counts for the front vs rear. It has a built in % it can deviate from but if this is over or under the abs computer will more than likely shut down the system and activate the abs lite. Worst case is poor braking.
Old Sep 12, 2003 | 09:46 PM
Mostwanted's Avatar
Re:tire situation
I decieded to go with 215.85R16, as I was told the dules would rub.
