why does my he351 oil drain not line up?
Old Apr 6, 2010 | 04:25 PM
1985cucv's Avatar
ok guys im wondering here my oil drain for my turbo is a little bit off from the oil pan im trying to figure out why it wont line up i have an ats manifold and this is on my 03 is there anything i can do to get it to line up? thank s
Old Apr 6, 2010 | 07:20 PM
JJPage's Avatar
Are you using the drain tube from your 03? The he351 turbo on the 04.5+ trucks has an accordian/flex type drain, where our 03's had a solid drain tube with a short piece of hose.
What ever you use, as long as it has a continuous downward flow you will be alright. If the drain tube has anything close to a horizontal bend, it will not drain correctly, and will back oil up into your turbo, and eventually into your intake or exhaust.
Old Apr 6, 2010 | 08:05 PM
1985cucv's Avatar
gotcha thats what i was wondering i guess im gonna cut the tube and line it up and go from there and put another piece of hose in there and hose clamp it i bet that will work good!
fade94
Feb 7, 2011 12:12 PM
fade94
TXDTR #8
0
Dec 31, 2010 10:39 AM
sgrooms
21
Apr 8, 2008 11:17 AM
VikingDiesel
17
Dec 30, 2006 09:19 AM
wooff
May 1, 2003 11:22 AM
