Where to buy wastegate solenoid plug?
you do not need the resistor. the cheapest thing you can do since you already have the boost elbow installed is to make the solenoid into a plug. you can do this in about 15 minutes. cut the solenoid into about 3/4 inch above the surface that mates to the turbo, remove the o rings first to keep from damaging. next there is some peaces in the center tube, shake them out and use a 1/8 inch npt to tap the center hole and screw a 1/8 pipe plug into it. reinstall the o rings and it is ready. if you had did this to start with you would not need the boost elbow. this opens up the waste gate to 32 psi. i neaten mine up by cutting the square shoulders deeper for wrench and remove some more of the outer steel if you need pix pm me your email
dodgediesel
Apr 15, 2010 09:00 PM
Swamp_Donkey
Jan 2, 2007 10:55 AM
TNfarmboy
0
Aug 20, 2006 03:02 PM
HOHN
Mar 7, 2006 05:33 PM
