Where to buy wastegate solenoid plug?
Old May 14, 2010 | 08:08 AM
fade94's Avatar
I have the ATS part number, 202-003-2272, but I can't get anyone over there to call me back or even reply to my emails.
So, does anyone know of a different plug or a plug that will work on the HE351 turbo?
Old May 14, 2010 | 07:38 PM
HUNTINNUT's Avatar
i made my own. if you have the electronic wg that is on the 351, cut the top off about 1/4" above where it goes into the turbo, then apoxy all of the small holes in the part that goes into the turbo. i did this and is working great and cost me nothing. i also tapped the top of the plug and put my adj. elbow in the plug instead of drilling another hole in the turbo. if you opt for this , i drilled a larger hole all the way through.
Old May 15, 2010 | 07:13 AM
Dodgezilla's Avatar
Why not just leave it the way it is? That's what I did. Then I just clamped off the wastegate hose....
Old May 15, 2010 | 09:22 AM
no_6_oh_no's Avatar
I think he is talking about the resistor to plug into the factory connection to stop CEL's. The WG controller is no problem, getting rid of the CEL and codes is.
Old May 15, 2010 | 11:34 PM
Spooler's Avatar
HTT sells them. That is what I have.
Old May 16, 2010 | 07:07 AM
Dodgezilla's Avatar
A $.50 Radio Shack 100 ohm resistor will work just fine. That's how I ran the setup in the 07 5.9 truck I had.....
Old May 16, 2010 | 07:52 AM
no_6_oh_no's Avatar
How many watts?
Old May 16, 2010 | 08:01 AM
Dodgezilla's Avatar
I don't know. It was 100 ohms though. I just wired it in on the engine side of the plug and it worked fine...
Old May 17, 2010 | 07:27 AM
fade94's Avatar
My truck is an 03' so I do not need the electronic plug in the turbo. I would like to remove it and sell it to someone who needs it. But, I'm not going to take it out if I don't have a readily available way to plug it.
Old May 17, 2010 | 08:08 AM
CD in NM's Avatar
100 ohm, 1/4 watt.
CD
Old May 17, 2010 | 05:38 PM
Dodgezilla's Avatar
There's one of those ATS plugs for sale at the "other" Cummins site.....
Old Nov 21, 2010 | 12:47 PM
2003Ram's Avatar
Ebay - $28
Holset HE351CW Turbo Wastgate Solenoid Boost Plug HE351
Old Nov 22, 2010 | 10:24 AM
kblranch's Avatar
John at ducu916@hotmail.com makes a replacement that is drilled and tapped for a boost elbow.
Old Nov 22, 2010 | 11:35 AM
fade94's Avatar
I need one that is not tapped that completely closes off all ports when installed. I already have a boost elbow installed.
Old Nov 22, 2010 | 11:53 AM
2003Ram's Avatar
The guy on ebay states that you can get it witout being drilled and tapped.
