Where is the best location for FASS pump?
So, the directions are a little vague and don't even give a recommended spot to mount it. Do I just put it anywhere??
Also, I haven't even looked at the stock LP yet but does it absolutely have to come off as per the instructions? I thought most guys were leaving it on as a backup..
I'm installing it this morning so if anyone has any tips please chime in...
The bracket mounts on bed rail on driveside rear wheelwell you should be able to disconnect fuel line from gas tank and plug new one in then run it to fass
pump then run line up to oem pump which is removed and put new hose adapter they provided on and hook up hose to it and wires hook up to oem pump conection and relay/fuse wires hook up the battery. Your good to go!
Your CP3 will love forever now!
Thanks guys. I installed it where pcburnout recommended. 19 psi is sweet but I feel strange not having hose clamps on the hose. It just seems strange but I guess they will hold..
klx650a2
01-31-2008 09:44 AM
ollie32
06-03-2007 09:29 PM
BCarmicle
13
11-07-2005 04:20 PM
