When to hookup edge juice?
Old Apr 23, 2009 | 10:09 PM
sallyman1's Avatar
when should a guy hookup a edge juice to a new engine? should a person wait till after break in? EEven with it hooked up id probably just drive on level 1 mileage. that shouldnt hurt one would think?
Old Apr 24, 2009 | 03:48 AM
Striper's Avatar
Are you serious? After everything that you have been through with your motor and all of the advice that has been given to you about ditching the Edge because it runs hot. Do yourself a favor, sell it and get the one programmer that most everyone else runs and has been proven to run cooler. I won't say it because I don't want to sound like a cheerleader but do some research. I'm sure you can figure it out.
Old Apr 24, 2009 | 06:44 AM
sallyman1's Avatar
are u serious. my truck only ran hot due to bad injectors.i cant get over 1150 for a egt anymore.on my old engine i could hit 1600 F stock.
Old Apr 24, 2009 | 07:08 AM
sallyman1's Avatar
so i shouldnt even put the edge on and use it for extra gauges and turbo timer? even on setting 0 its going to melt pistons?just for a side note i dont race or drag any1.i melted a piston before because i passed someone on highway. even when i tow my 12000lb camper i only use setting #2 at the most. so with this all said and done i shouldnt try it?
i know edge runs hot but how much hotter on a perfectly running vehicle?instead f seeing 590 egt on highway will i see 690 egt now lol if so how can i melt piston at that temp?
Old Apr 24, 2009 | 07:09 AM
Striper's Avatar
Oh, ok... Then go ahead and run your Edge HOT. Good luck...
Old Apr 24, 2009 | 09:07 PM
aborgardt's Avatar
I've always been a believer of break it in how your gonna drive it.......
Old Apr 24, 2009 | 10:07 PM
madhat's Avatar
Administrator/Jarhead
I agree. Just make sure you bring the engine up to temp easy, then drive it like you stole it once the T-stat opens.
Just keep an eye on that EGT, sally. I have personal experience on how hot an Edge can run. It's a good box, but there are better ones.
On a side note, my Edge EGT gauge was always off. I would suggest getting a good analog mechinical gauge with a high end probe.
Old Apr 25, 2009 | 06:55 AM
sallyman1's Avatar
i got one. i have isspro gauges for a year now. boost tranny and pyro.ill hook up the edge and see my egts. if they arent in check im throwing the edge in the garbage. i dont race or drag so i should be fine. when my engine blew up a few months back my edge was on 0 stock. a injector stuck open and melted #1...comprenday
Old Apr 25, 2009 | 09:33 AM
jiggerman78's Avatar
I wouldnt be scared with it...Any chip or programmer can run hot just depends on how you push it. If you see high temps back out of it and all problems avoided.
Now to waste money and get something else just because it runs hot is stupid. Like said earlier just take it easy until the T-stat opens and your fine not every level of the EDGE puts down 100hp so just use the shift on the fly to your advantage and start out low till you find what you like.
Old Apr 25, 2009 | 08:12 PM
hickeyman's Avatar
jiggerman78, Is right any programer or chip will do it! Its just how hard you push it and yes I've tried some of the other programers and they all did the same on heat on my truck.
My anolog gauges and digital gauges on the Edge are pretty close with in 15 -20* I'm not preaching either on which one is the best. I have what works well for me and for the combo I have.
Old Apr 25, 2009 | 10:10 PM
Farmall Power's Avatar
My edge on 5 i can run it fairly hard and it only goes to 1200 or so.
Old Apr 26, 2009 | 06:58 AM
sallyman1's Avatar
exactly hickey man exactly. im not dumb. if i hook it up and run down the highwyay and see numbers creeping over 1200 F i will instantly let off . this time i wont go over 1200-1250 F at all.i will also set edge to defuel at 1100 F and set max boost to 32 lbs...
sabercat
Sep 17, 2010 06:08 PM
MrSuzuki
Aug 25, 2009 07:22 AM
razor6
22
Jan 20, 2006 03:43 PM
djcheez
Oct 15, 2005 04:13 PM
king d
Sep 5, 2005 01:29 PM
