When do studs become necessary?
Old Feb 21, 2007 | 08:18 PM
powerstrokin03's Avatar
With the mods listed in my sig, am i messing with fire by not having studs or am i safe for the time being?
Old Feb 21, 2007 | 08:35 PM
judge88's Avatar
probaly not but for 400 bucks there well worth it. its gonna cost you 2 times that if your hg goes. too much timing,,cylinder pressure, drive pressure, boost and drugs all will cause a hg to go. the mls gaskets are pretty incredible though compared to the 2nd gens. i say put them in.
Old Feb 21, 2007 | 08:37 PM
morkable's Avatar
The rule of thumb is 50psi boost. The only bad part about studs is the cost of install. It is quite labour intensive.
Kevin
rustyshakelford's Avatar
X2 judge. its a relatively inexpensive way to give your HG some protection
brett
Old Feb 21, 2007 | 08:50 PM
Luken's Avatar
There is alot more to it than boost alone. Ive replaced 2 hg's on my truck. Put the studs in. Its an easy install... Alot easier than taking the head off.
Old Feb 21, 2007 | 08:59 PM
973604x4's Avatar
Kevin
Agreed!
also agreed you need studs.
Old Feb 21, 2007 | 09:05 PM
morkable's Avatar
I am personally of the thought that if you put in studs you should pull the head and put in a new gasket,, hence why I say it is rather labour intensive... I know that there are plenty of guys out there that have done it without pulling the head, but there just is too much chance for my liking
Kevin
Old Feb 21, 2007 | 09:48 PM
abc4yew's Avatar
The general rule of thumb is that if you properly replace each stud one at a time with the seated head gasket in place then you don't have to retorque the studs after a couple thousand light foot miles of heating and cooling cycles. If you put in a new head gasket be prepared to retorque at least once which means taking the valve cover off and removing at least the exhaust rockers every time. I retorqued twice and each time there were looser studs. ks
Old Feb 21, 2007 | 09:54 PM
morkable's Avatar
I checked mine here before the weekend, and they all seemed to be good,, but I am going to keep my eyes on that
Kevin
leeboy
Dec 22, 2014 09:48 AM
77machomopar
Nov 30, 2009 11:55 PM
Lightman
Feb 11, 2004 07:25 PM
cethane
Jul 25, 2003 01:55 PM
