Whats the Best????
Old Sep 12, 2005 | 04:03 PM
rrsmtd's Avatar
Whats the Best????
Hello,
I am new to the forum. I bought a new 05 dodge ctd last month. I am wanting to get more performance and mpg out of it. I here banks,bullydog,edge, and quadzilla are the main modules. Which is the best? Is there an up grade on the exhaust I can go with? Thanks lmk
Old Sep 12, 2005 | 04:22 PM
YFZ's Avatar
YFZ
I almost went with the Edge Juice w/attitude. I ended up going with a quad box and analog gauges. I couldn't be any happier...
Furthermore, in case I need to take the truck in for warranty repair, the box gets removed and no need to explain them the wires leading to the tranny, intake and exhaust manifold.
Old Sep 12, 2005 | 07:46 PM
Bart Timothy's Avatar
TST and Bully Dog downloader used together. The best.
Old Sep 12, 2005 | 08:37 PM
bigman's Avatar
If you plan on adding fuel you will first need at minimum an egt guage. After that there are several great options for you. I would reccommend you stay away from fuel pressure only boxes. I like a little moderation . Look for a product that does duration and timing or all 3 , duration, timing, and a little fuel rail pressure. I like the bullydog downloader, and the tst if you have self control. My edge juice had big problems and is at edge getting looked at. When they work however they have some nice features that back down fueling when the box sees high egts or tranny slip. Nice but kind of a rats nest install. I also doubt the accuracy of the built in guages on the attitude. Remember if you go much over an additionial 80 hp your tranny will not like it. Cheers!
flashgordon
Mar 26, 2006 01:27 AM
The Domie
Jan 6, 2005 02:23 AM
spassey
Jan 25, 2003 12:08 PM
OH Sick
15
Dec 16, 2002 07:09 AM
