What temp to start adding power?
Old Aug 16, 2006 | 07:21 AM
yelloz28's Avatar
Question What temp to start adding power?
I was curious as the commander has the function that allows you to turn your module on once the engine reaches a certain temp, what is the minimum temp that the engine should be at before you start adding power?
Old Aug 16, 2006 | 07:31 AM
4x4not's Avatar
I have mine set at 160°, but if you want to be really safe I know my old Juice didn't add power until 174°
Old Aug 16, 2006 | 01:13 PM
RamWheelsBy4's Avatar
The Edge 174* number was explained as full operational operating temperature. Seemed reasonable. I know when I get on mine with the TST before it is past that temp I usually throw a P0336 code. Not good to create high boost on cold parts.
Old Aug 16, 2006 | 02:32 PM
JCLeary's Avatar
I leave my power "on" all the time. At first I used to worry about it, but I know I'm smart and not abusive. I just exercise restraint and wait 'til the needle's in it's right spot before hammering on the throttle. Personally I would set it at 174° or above. My TST has never to my knowledge caused a code unless I lug it below 1200 by accident.
My greatest worry is the effect of 55psi of boost on a cold head/head gasket. I don't think it would put up with it for long.
Old Aug 16, 2006 | 03:05 PM
qzilla's Avatar
I set mine on 160 degrees and never have an issue.
williamdr
22
Dec 4, 2015 03:03 PM
staarma
14
Apr 23, 2014 09:01 AM
PowerWagon500
Mar 31, 2012 05:50 PM
jlells01
13
Oct 27, 2004 04:25 PM
