Adding MOPAR OEM Remote Start to 2007 Ram 2500 6.7
I would like to add the OEM remote start to my 2007 2500 6.7 SLT MEGA Cab. I have a few questions if anyone knows the answers.
1) If I install this myself, will I have to still go to a dealer to have any reprogramming done?
2) I understand this unit cranks the vehicle without having to have a key in it; If I then get out, and leave it running, can I lock the doors with the FOB and it'll will continue to run if I want to leave it idling while I run in a convenience store?
3) I've read the install directions and they don't look too bad as long you don't get in a hurry, has anyone done this install themselves and how bad was it?
4) Is the additional 2-way communication component worth the extra money and what exactly does it do?
If there are any comments good, bad or otherwise about these remote start units, please share them.
Thanks.
PS -- Forum Admin, If this should have been posted in the aftermarket accessories, please move it.
Thanks.
1- No, it shows in the manual how to set all of the functions/options you may want. including the delay for diesels.
2- If you start the truck in remote start mode. It will run untill the brake is depressed unless you insert key first and turn to run.
3- Have done several of them at my shop. The Mopar remote start is by far the best remote start system I have ever seen. Everything is color coded exactly the same as the wire it is supposed to tap into. If you can solder and use a screw driver its simple. Takes me approximately 1-2 hours to install one.
4- I don't have any knowledge of the 2-way com. device. Maybe someone else can help you out with that option. I have only installed the basic systems.
Over all. Its a wonderful system. I installed one on my 1500 Ram and loved it. Certainly worth the money.
The two-way is nice because you after the truck starts it will send a signal back and tell you it has successfully started. That way you don't have to go over to the window and try and peer across the yard or parking lot to see if your truck is running. Definitely the way to go!
From: Shreveport LA for 10 days at a time, Groveton TX the rest
I would like to know more as well. Where can I pick one of these things up and why isn't stuff like this factory installed? It would make life so much more simpler!!
I am glad I saw this thread. The next mod to my truck will be a remote starter, but I don't want to spend $500 on one from the local stereo shop. You guys mind posting the price for the Mopar unit?
the remote start will stay on for 10 min when u get to a store and live it runing u just need to press on the start button on the alarm twice and then u can take the key off just dont step on the breake you can still luck the door w remote at that point also the pager will beep if the alarms goes out u can even check the temp out side w the remote i haave that system in all my car i just need to get it for my dodge i got install for 200 in old f30 super duaty i can get the alarm for less than 150. the prestige brand
