What support mods for Smarty
Old Oct 6, 2009 | 11:10 PM
Clmsnow's Avatar
As seen in my signature line, I have a Smarty. I usually run it on SW5 and keep all the settings on mild. I drive it relatively sane...... However, if want to turn it up, but I cant fork out $5000 for a new tranny. What is the bare minimum I need as far as tranny and fuel support? When I tow, it is only 5000lbs, and I turn the Smarty down regardless. I am not doing 4wd boosted launches or drag racing......other than against all my buddies in the Durmaxes Would a TC and VB with a fuel pump be enough?
Old Oct 6, 2009 | 11:29 PM
annabelle's Avatar
Tranny, turbo, injectors......depends on how much HP ypu want to make.
Old Oct 6, 2009 | 11:34 PM
Clmsnow's Avatar
....I am asking with just the Smarty, whats needs to be done to the tranny and fuel system to keep from blowing things up??? I want to run the Smarty on SW7 or SW9.
Old Oct 7, 2009 | 12:24 AM
annabelle's Avatar
Ok, build your tranny and then get a FASS or an Dog fuel pump.
Old Oct 7, 2009 | 07:34 AM
rip 112's Avatar
See thats the thing you don't grasp fully. The Smarty is capable from mild to wild.
You really need to set yourself more on a horsepower goal.
The main concensus is transmission work. (T/C, valvebody, possibly billet internals, etc)
Fuel System. Research, research, research, you will find your answer quick.
Honestly doing those 2 things will pretty much get you where you want to be.
If you don't have gauges yet make that a priority.
Old Oct 7, 2009 | 09:23 AM
Clmsnow's Avatar
I have the gauges already and air intake and exhaust. I would like to be around 500hp, but for now, I just want to be able to run my Smarty on the highest levels without hurting anything. I heard just a VB and TC would be enough as long as I don't tow on level 9 or thrash the truck. At the same time, I also hear that I need a FASS or something like that to meet the fuel requirements of the Smarty on higher levels. That is my basic question, with the Smarty being my ONLY power enhancement(no other controllers, turbo or injectors) what needs to be done to the tranny and fuel system?
Old Oct 7, 2009 | 01:07 PM
annabelle's Avatar
TC, VB, I would do Billet shafts. Also, after market LP.......you are looking to run my exact setup.
Old Oct 7, 2009 | 04:12 PM
Clmsnow's Avatar
Can I run the Smarty on SW 9 without the LP?
Old Oct 7, 2009 | 06:03 PM
BigBore050's Avatar
I run my smarty on SW 9 with TM on 4 with only the mods in my sig, been running this setup for almost 6 months and i run the **** out of it. but have a 6-speed with stock clutch(no slipping yet). my FP will drop to 1 or 2 psi at WOT but the RP will hold and not drop off so 1 to 2 psi is just fine for me, the only thing holding my truck back is EGTs in a 1/4 mil pass i would see 1600 which is to hot for me
so i would say your major hold back is your auto might as well go full built now rather than later wish i did on my old truck
Old Oct 7, 2009 | 06:22 PM
JJPage's Avatar
Yes, you will just run out of rail pressure, but you will not hurt anything. You may make more power on sw7 than sw9 with a stock lift pump.... maybe even with an aftermarket lift pump.
As far as the tranny, minimum, tq converter, valve body, billet input shaft.
Old Oct 7, 2009 | 08:41 PM
annabelle's Avatar
I ran my rail dry with a stock LP.
Old Oct 7, 2009 | 11:22 PM
Clmsnow's Avatar
So the Billet Input shaft is necessary? What LP should I look at and how will it help?
Old Oct 7, 2009 | 11:27 PM
annabelle's Avatar
Not necessary at 500 HP but would be a good idea while you are modding the tranny......FASS or Air Dog or an other high output LP.
Old Oct 8, 2009 | 12:22 AM
Clmsnow's Avatar
Any performance gain from LP?
Old Oct 8, 2009 | 12:29 AM
puffsmokeonya's Avatar
these new trucks can hit 2600 in a 1/4 pass and not hurt a thing. i promise you this.
