What Stackes Best With The Edge (HOT) Juice W/attitude
Old Nov 8, 2005 | 03:02 PM
jerrywoodie's Avatar
On An 05 With The Edge (hot) Juice W/attitude What Stacks Best With It
Old Nov 8, 2005 | 05:06 PM
djgaston's Avatar
I put the Edge EZ on mine and it does very well... they are a good pair.
Old Nov 8, 2005 | 05:18 PM
drew03's Avatar
would'nt that just suck the stock fuel system dry?
Old Nov 8, 2005 | 08:33 PM
djgaston's Avatar
Yes, and then you get a FASS pump and bigger injectors... but then you have too much fuel so you need a better turbo... upgrade the stock turbo... then you need more fuel...
No, I have not run mine dry yet but it gets down pretty low I'm sure. I still need to hook up a gauge to see for sure.
Old Nov 8, 2005 | 09:34 PM
RamWheelsBy4's Avatar
Well I stacked an EZ with the HOT Juice/Attitude on mine. Of course Juice on 5/5 and EZ on 2 sucked the lp to 00000. The FASS and II SPS66 made it a very good stack. No issues at all, and smooth adjustable consistent power all the time. Low end to high end, it will pull all the way. Ran consistent 13.8 1/4 miles and never had an EGT get over 1300. It would dyno about 190rwhp over stock with that combo. Very good will no problems. Unfortunately I wanted more. Now have TST(twins) BDDL Triple Dog with Crazy Larry and the EZ. Not sure which combo is going to pop the rail pressure relief valve, but I am sure one will.
Old Nov 8, 2005 | 10:26 PM
Bobcat698's Avatar
There is a HOT Juice now out for the Commonrails? Where at? Edge doesn't advertise it...
What are the ratings?
Old Nov 8, 2005 | 11:56 PM
lightening ram's Avatar
hot juice
i found that the dr. performance 2021 adjustable 100hp works well with this, i found the edge hot juice doesnt have any high end power for when pulling heavy loads, with the 2021 made a large difference in towing, proved it against another truck identical to mine without the stack both pulling equivelent loads and mine outpulled it hands down this is my experience.
Old Nov 9, 2005 | 12:03 AM
bobcat698
There is a form on the Edge web site for upgrade to HOT Juice version. It is not advertised, but for the 04.5 600 and up it has been out for a while now.
For the 04.5 600 and Up the level ratings are:
Level 1 40hp
Level 2 60hp
Level 3 80hp
Level 4 100hp
Level 5 180hp
Not sure what they are for the 305/555s, but about the same.
Old Nov 9, 2005 | 08:16 AM
Mark Craig's Avatar
Bobcat698,
You can call us and we will get you one of them, they are very very popular with the folks wanting max HP and don't want to stack etc. You have to sign a release form and then we ship it right out to you.
Mark @ DPPI
1 Bad '02 HO
Jan 20, 2008 06:21 PM
cbrahs
41
Aug 25, 2007 12:18 AM
reidsram
Feb 10, 2007 05:06 PM
razor6
22
Jan 20, 2006 03:43 PM
maui diesel
Jul 28, 2005 07:54 AM
