What injectors to go with?
Old Oct 18, 2007 | 01:47 PM
mm73's Avatar
I was looking at getting some injectors after I do some trans mods and a fuel system. I was looking at anywhere from 90 to 200 hp injectors. Just wondering which ones to look at. And if I get some do you have to get a turbo then also or will the stock one hand for a little while?
Old Oct 18, 2007 | 01:56 PM
soulezoo's Avatar
DTR 1st Sergeant
Stock injectors are capable of putting out a lot of fuel on their own. Most people go turbo first. Big injectors with stock air = high egts and lots 'o smoke. You will not be able to effectively utilize the extra injector size until you give it more air. This mod thing has to go hand in hand to a degree... How's your tranny??
Old Oct 18, 2007 | 02:02 PM
Dwitt0187's Avatar
Ddp 90 Will Be More Than Plenty With Stock Charger They Are To Much You Really Need A Charger Before Injectors On These New Motors
Old Oct 18, 2007 | 02:08 PM
mm73's Avatar
So far my tanny is good but I know it needs to be upgraded because eventually it is going to give out even though i baby it. As far as the injectors and all go, I am glad I asked because I wasnt sure what to do next or why, I guess I need to start looking into turbos then. There is just so many to choose from and look at. Well once the turbos are done, then the injectors will be good to run?
Old Oct 18, 2007 | 02:10 PM
cquestad's Avatar
Flux 1's and your stock charger would be fine.
But...you really need to ask your self this...
How much air and how much drivetrain/tranny can you afford?
Then buy the fuel!
Old Oct 18, 2007 | 02:11 PM
cquestad's Avatar
Basically...what are your hp goals...and for what use?
Old Oct 18, 2007 | 02:16 PM
mm73's Avatar
I know I want the trans done right the 1st time and as for the turbo, I dont want to have to go through 3 or 4 dif ones I want one or maybe 2 that are good for keeping things cooled down. I plan on using the truck to drag, or basically to make rice burners and strokes and dmaxes feel stupid. My goal is 600 to 700 hp.
Old Oct 18, 2007 | 02:19 PM
cquestad's Avatar
OK...
Trans...built to the hilt...from somebody ASAP.
Aurora 5000 if you want a single...
or take your pick Twins...
I would say MPI Twins!
Flux 2's or slightly bigger...
Stage 2 Floor It pump...
You got it!
Old Oct 18, 2007 | 02:29 PM
soulezoo's Avatar
DTR 1st Sergeant
If you go with twins, you get to join a cool club here!
Old Oct 18, 2007 | 03:19 PM
mm73's Avatar
should it be in that oder? and if so, would that put me in the range of hp that I want to hit? Oh and thanks everyone for the info.
KRB
May 20, 2007 06:20 PM
GSP
Dec 11, 2005 12:20 PM
W.F.O.
Nov 3, 2005 10:33 AM
darrenG
Jun 21, 2005 10:24 PM
BIGOKIE
Jul 21, 2004 05:53 PM
