Water-n-Fuel sensor after FASS
Old Aug 14, 2005 | 04:50 PM
RamWheelsBy4's Avatar
All you with FASS systems installed, what did you do with the Water n Fuel sensor in the original Fuel Filter canister??
FASS is in and working fine, we just really did not know the best thing to do with the fuel sensor(s) that were bypassed. I had the original fuel stuff left in place, just in case ever need to use again. So for now the fuel filter canister still has diesel in it. What will happen if I drain and plug everything up?
Thanks in advance.
Old Aug 14, 2005 | 06:07 PM
smokindog's Avatar
I installed the FASS in January and just removed the old filter canister within the last couple weeks. I just took the WIF sensor and plug to the fuel heater and taped them up good and tied them back against the firewall. I don't suspect I'll need them anytime soon.
Old Aug 14, 2005 | 07:33 PM
RadRam's Avatar
I have my Fass system installed so that I use the stock fiter canister, I use the Scotty big fuel lines & the Scotty adapter - No problems with this set up either.
dart3404
Oct 12, 2009 03:35 PM
rjm022
Jul 8, 2006 06:30 PM
tyssniffen
Feb 11, 2006 01:28 PM
caffecapri
Feb 2, 2006 12:38 PM
