Walbro and Cat 2 micron filter install
Old Apr 24, 2006 | 10:48 AM
  #46
trik396's Avatar
Sounds like your setup is identicle to mine.
btw-GN's are my favorite muscle car. Never owned one yet, but someday...
Old May 26, 2006 | 03:59 PM
  #47
ckennedy's Avatar
so whats the longest time frame one has had a walbro electric going on one of these applications??
Old May 26, 2006 | 05:04 PM
  #48
trik396's Avatar
I'm pushing around 7000 miles. So far, so good...Plus I added a 2 micron filter after the stock filter and an 85micron pre-Walbro filter. Still seeing 19-20psi at idle.
Old May 30, 2006 | 10:50 AM
  #49
cquestad's Avatar
I like the prefilter idea...more info please!
Old May 30, 2006 | 12:57 PM
  #50
trik396's Avatar
I think I have a pic in cummins forum. Its just an 85 micron screen type inline filter from Jegs or Summit. About 30 bucks if I remember correctly. You can take it apart and clean the screen and reuse.
Old May 30, 2006 | 03:00 PM
  #51
B.Law's Avatar
I used a fairly cheap Jegs brand billet inline, I think it filters down to 40 micron and has -06AN fittings. Either I have been lucking out and getting clean fuel, or all the particles have been less than 40 micron because I just checked it the other day and it was still clean. This is with maybe 5k miles on it.
I believe this is the one. Jegs Pre-Filter
Old May 30, 2006 | 04:02 PM
  #52
trik396's Avatar
Mine is very similar except its an Earl's filter. That is the first time I've seen those from Jegs... and they send me catalogs continuously and I'm on the website alot also... hmmm
Old May 31, 2006 | 10:20 AM
  #53
B.Law's Avatar
Hey Trik, what 2 micron filter are you using? I am using the Cat with a Perma-Cool filter head, but the head isn't quite big enough and it leaks a tad. After a few hours of driving you can see a couple drops accumulate on the bottom of the filter, it's not enough to coat the bottom of the truck, but still annoying. Just curious as to what you are using.
Old May 31, 2006 | 10:42 AM
  #54
cquestad's Avatar
Give Glacier Diesel a call...he has a head that works great with Fleetguard filters.
Old May 31, 2006 | 10:43 AM
  #55
trik396's Avatar
Currently running the Permacool filter that came with the head. Was going to switch to the Cat in about 10k miles... but now ???
Old Jun 1, 2006 | 10:19 AM
  #56
ckennedy's Avatar
what about heat to the filter in cold climates/winter ?? what are you doing for that??
Old Jun 1, 2006 | 10:41 AM
  #57
ckennedy's Avatar
filters
what about using something like a RACOR 490 diesel spin on filter.. rated for 90GPH (341 L) has a electric bowl heater - clear see water drain bowl - 3 micron filtering - (not sure but I think you can get a 5/7 if wanted ?? - at least on others).. good for 30 PSI.. just adjust the bypass for around there??
gives you better filtering
have heat if needed
have see-em drain bowl
Old Jun 1, 2006 | 10:46 AM
  #58
trik396's Avatar
Still using stock filter with heater. No problems last winter.
AH64ID
66
Dec 20, 2012 08:09 AM
1985cucv
Nov 16, 2009 05:01 AM
03RAM2500
Jan 11, 2009 05:21 PM
Smokeman
Nov 25, 2006 08:03 PM
ptgarcia
37
Sep 14, 2006 01:13 PM
