van Aaken C 3.2 turbo problems
Location: Drive till ya hit a Polar Bear, then go back 50 miles
If we're talking bearing and shaft sizes, the B1's shaft is a full 1mm larger than a 40, and the bearings are much larger. I've got some comparison shots a little ways down on this page:
http://www.wildcatdiesel.com/dodgeturbo.htm
Rod
Rod
Rod
Rod
Compressor side
Turbine side
Originally posted by Gypsyman
Lenny said he thought Ken was having a John Deere style housing cast for this application. Here's the B1-04 compared to the HY-9...
Rod
Cool. Thanks for the info Rod. Any idea from the looks of the pictures what this would compare to flow wise. I'm not looking for part numbers or proprietry info, just trying to find out what I'm working with here as I happily bomb away.
Thanks,
Richard
Thanks,
Richard
According to TAD, the B1 compressor side is capable of flowing almost 1000 cfm at 40 PSI. We did some snooping a while back at some Schwitzer maps, and did indeed find some maps that crossed over to the numbers Ken was quoting me.
On the turbine side, we've got a few customers running B1-04s. They've been able to dyno 500 HP+, but heat has been a killer on the street. The external waste has relieved many of our EGT issues on the higher power level settings, although until F1 gets their injectors ready for us, I don't think we'll see 500HP thats safe for the street.
Rod
Rod
Rod
Rod
By externally W/G the turbo is it the relief of the super high drive pressure that can help cool the EGT's down?
At the 500hp level how hot can these motors run with the B1-04's? I know that every truck is diffrent but can you give an estamate at what you have seen?
John at Floor It Diesel says he is making 590+ hp with a B1/TST/EZ at 60+lbs of boost. Is this capable?
I mainly run 5/5 TST daily and I have dynoed at 377 at this setting, 450 on 8/8, So lets say that a set of F1 EDM's or a pressure box and im at a good, less aggresive 450 on the street and want to tow light at say 3-4k, at the high 3-400 hp. Can the B1-04 keep me cool?
Thanks for your info Rod!
Originally posted by mattymac
1) By externally W/G the turbo is it the relief of the super high drive pressure that can help cool the EGT's down?
2) At the 500hp level how hot can these motors run with the B1-04's? I know that every truck is diffrent but can you give an estamate at what you have seen?
3) John at Floor It Diesel says he is making 590+ hp with a B1/TST/EZ at 60+lbs of boost. Is this capable?
4) I mainly run 5/5 TST daily and I have dynoed at 377 at this setting, 450 on 8/8, So lets say that a set of F1 EDM's or a pressure box and im at a good, less aggresive 450 on the street and want to tow light at say 3-4k, at the high 3-400 hp. Can the B1-04 keep me cool?
2) At 500 HP, the non-wasted B1-04 will TOASTY, in the 1800F range. Waste them out and you'll see those numbers drop significantly.
3) We've never seen 590HP period on a common rail truck. But John may know something we don't
4) The injectors are a large part of the EGT equation. Don's been giving me some EGT numbers from his testing data, and they are definitely going to be part of the equation when producing usuable horsepower on these trucks.
Rod
Thanks Rod!
But can you help me with 1 more question?
Say at 400 HP can a B1-04 keep me cool enough to tow at about 5000 ft with about 3-4000k lbs and still stay cool?
I am willing to go twins but I dont want to if I dont have to. I trailer race in the winter, if it cant keep me cool I will put water/meth on to help drop some temp.
what would you say with the TST/ dons 40hp TST EDM's, B1-04 and water/meth at 400-450 HP towing stated above?
Thanks agin Rod.
Thanks agin Rod.
1 Post
1) Say at 400 HP can a B1-04 keep me cool enough to tow at about 5000 ft with about 3-4000k lbs and still stay cool?
2) what would you say with the TST/ dons 40hp TST EDM's, B1-04 and water/meth at 400-450 HP towing stated above?
2) I don't really know the answer to this one. Don's injectors have been running cooler during his testing than the stockers, so I would say definitely. Do yourself a favor though, and stay away from the water/meth. Too many bad experiences with water/meth for me to recommend it to anyone.
Rod
torquet
02-23-2008 10:52 PM
cantfindaname
11-28-2005 07:46 AM
Original Junior
01-15-2004 12:26 AM
Copenhagenjunkie
05-19-2003 08:04 AM
