Undermods people have studs?
Old Jan 22, 2008 | 09:35 PM
sallyman1's Avatar
This may be dumb? but what are the studs that people use in their mods? are you replacing head bolts with stronger studs? Do studs hold that much better? do any 3rd gen 5.9 diesels have bolt/stud problems?
Old Jan 22, 2008 | 09:39 PM
Billm2004's Avatar
over 50 PSI you should have them. Its better to fix the problem before it happens. Im getting ready to do mine cuz im right at 50 now, and soon im getting injectors too so ill need them
sallyman1's Avatar
over 50 psi boost? what do we have from stock? studs or bolts and whats better? why do some have orings?
Old Jan 22, 2008 | 09:41 PM
Billm2004's Avatar
im not too sure about o-rings, some people swear by them, and some say its not needed. from stock, im pretty sure they are bolts, but this is my first diesel so someone will correct me if im wrong
Old Jan 22, 2008 | 09:42 PM
Billm2004's Avatar
stock boost is like 26 psi i think. but with a fooler i was getting around 45.
Old Jan 22, 2008 | 09:44 PM
skynyrd's Avatar
bolts are stock. the studs apply more clamping force to the head to allow for higher combustion pressures in the cylinder which comes from running more PSI and bigger injectors. the o-rings are to create a ring that is clamped tighter around the cylinder edge.
leeboy
Dec 22, 2014 09:48 AM
77machomopar
Nov 30, 2009 11:55 PM
dieselfuelonly
Mar 24, 2009 03:44 PM
herb
Jul 18, 2005 01:23 PM
kingofdodge7131
Jan 26, 2005 09:32 AM
