Undercover Tonneau & Line-X
Old Jun 20, 2006 | 10:08 PM
pet05's Avatar
PICS are in my members gallery.
Got the Line-X done = $400.00 (over the rail)
Got the Undercover Tonneau ($780.00 installed)
The cover is GREAT. It locks at both ends preventing someone from opening the tailgate. It has gas struts. It is easily removable (weighs 55 pounds). Has an LED light.
I bought it so I can transport/store items in the cargo bed securely and without them being exposed to the elements and people. I can take it off easily if I need to transport something larger.
I might even gain 1MPG on the highway due to its aerodynamic features!
Old Jun 21, 2006 | 08:34 AM
Cruzin90's Avatar
I'm a LINE-X dealer.
As far as hard tonneaus, we sell more Undercovers than anything else. Good choice of bedliner and tonneau.
Old Jun 21, 2006 | 08:49 AM
Dodge2500CTD's Avatar
Where are you located pet05? I live in McKinney, TX and got a quote to do Line-X over the rails for $519. I have not pulled the trigger yet.
Old Jun 21, 2006 | 10:12 AM
RamWheelsBy4's Avatar
I have the same combo, Undercover tonneau has been on for about six months now and I love it.
Old Jun 21, 2006 | 10:24 AM
Henry F. Smith's Avatar
Smile
Same two products for me. Undercover is off at least once a month, no big deal other than it does require two people. Line-X dealer in Fresno has resprayed worn areas (my fault) on two different occasions as part of his warranty. Very satisfied with both products and my dealer.
Old Jun 21, 2006 | 11:10 AM
Cruzin90's Avatar
Curious: Who did you get that quote from?
Old Jun 21, 2006 | 11:19 AM
pet05's Avatar
I would shop around. Each Line-X shop is independantly owned so the rates will vary. I got it in Phoenix, AZ.
Old Jun 22, 2006 | 07:35 AM
I got the quote from the local Line-X shop in McKinney, TX.
Old Jun 22, 2006 | 07:44 AM
truckjunkie's Avatar
I have the Undercover as well -
ONE THING TO WATCH OUT FOR: make sure you check the brackets every once in a while to make sure they're aligned properly, and the bolts haven't loosened up. I have a couple of places on my truck where the paint has been rubbed by the Undercover due to it not aligning properly. I also had to take a Dremel tool to one of the leading edge corners of the Cover because it was constantly rubbing, even after I adjusted the brackets.
Since I've done that, the Cover works fine, and I agree it's one of the most versatile ones out there.
Old Jun 22, 2006 | 08:17 AM
Cruzin90's Avatar
For those in the DFW area, I have Undercover's on sale. See the "Four Specials" at www.linexfortworthtexas.com
Old Jun 22, 2006 | 04:18 PM
WACTD's Avatar
I have the same combo, love both products...
The Undercover is wonderful. It does take two people to safely remove it (unless you don't worry about dinging your truck) but I've heard the more "traditional" fiberglass tonneaus can weigh hundreds of pounds - making their removal a BIG event. We pop our Undercover on and off whenever it's convenient.
The Line-X is solid, too. The only thing that's dinged it so far was a full-sized fire hydrant. I asked a guy to help me get it out of the truck and even though I was lifting my end he started DRAGGING his. The sharp edge backed up by 100+ pounds of weight took a dime-sized chunk out of the Line-X. Definitely not the Line-X material's fault - it would probably have scraped a hole if the bed metal had been exposed.
I strongly recommend both products.
Old Jun 22, 2006 | 04:31 PM
Cruzin90's Avatar
You can have the ding repaired free. Go to any LINE-X dealer and they will take care of it.
Old Jun 22, 2006 | 09:11 PM
dale29's Avatar
Thumbs up
Undercover and Bedrug
AkitaSumo
Oct 29, 2007 01:32 PM
TurboT
19
Jul 31, 2007 02:42 PM
RyeThomas
Jan 18, 2007 01:36 PM
reidry
Aug 28, 2006 02:24 PM
Shovelhead
Jan 5, 2003 10:22 AM
