Twins question
Old May 21, 2009 | 11:47 PM
turbo hoss's Avatar
Twins question
Is there a twin set up for a stock motor no programmer? Just wondered if anyone ever heard of twins on a bone stock truck.
Old May 22, 2009 | 12:51 AM
Nsomniac05's Avatar
BD towing twins sounds right up your alley.
Old May 22, 2009 | 09:32 AM
soulezoo's Avatar
DTR 1st Sergeant
With stock power there is not much use for twins as your stock turbo is engineeered to be that complimentary to what you would make stock and any other good single turbo will do the job as well at a much lower price and not nearly as complicated. However, BD tow twins or garrett twins would do it if you had to have them.
Old May 22, 2009 | 04:08 PM
DaveB.inVa's Avatar
I think it was Diesel World that recently put ATS's Aurora Plus Compounds with an A4000 under the stock turbo on a stock truck with no other mods except boost fooling. I think they dynoed about 40 more horsepower and the EGT's were nearly impossible to get over 1000 pre turbo loaded.
I think the A4000 compounds are one of the cheapest too.
Old May 23, 2009 | 03:21 PM
Jfaulkner's Avatar
Muted User
I don't see much benefit to this. Sure your EGT's MAY be a bit lower but for the cost there are probably better and easier ways to get it. I know on my truck if I drive it without any added power (stock programming and TST off) it's an absolute pig. You learn real quick not to pull out in front of anyone or your going to die. I have a smaller set of twins (2.6" S300 and a 3" S400 with external wastegate). But I'm sure if you want a set someone will make you one, money talks.
dodgediesel
ABDTR #5
Oct 18, 2011 09:22 PM
dodgediesel
ABDTR #5
496
Oct 16, 2011 04:33 PM
dodgediesel
17
Apr 5, 2011 11:21 AM
Stock 02
28
Sep 24, 2006 11:09 AM
stlsparky
Nov 21, 2005 10:02 PM
