Twins and engine durability
Old Feb 23, 2009 | 09:43 PM
RAMRODD's Avatar
Or can I need some opinions about tuning my ATS twins 3000/5000.
How high of boost can my 06 take before effecting head gausket life? I have run a lot of miles running 40psi on the stock turbo pulling with no problums.
Now with my smarty on 3 and the TST on 1/1 I will hold 45 pounds of boost I am thinking this should be safe. What do you think? What is the Max for stock headbolts?
I tried Smarty on 3 and TST on 2/2 hit 55 almost instantly and I let off
Where should I set the wastgate, 45? I am more consirned about reliabilty right now then big power.
Studs are in the future but more then likely not for a few months. With studs where can I safely set my wastgate and still use my truck as a tow rig?
One more question, is it true you shouldn't go over 60 psi with stock valve springs?
Old Feb 23, 2009 | 10:39 PM
OldSmokey's Avatar
If your exhaust temps stay low keep it wastegated at 45. Yes 60 the save level with stock springs
Old Feb 25, 2009 | 03:35 PM
wap's Avatar
wap
What year is your truck?
Old Feb 25, 2009 | 03:40 PM
Megadeth's Avatar
^said 06 in original post
Old Feb 26, 2009 | 06:29 AM
wap's Avatar
wap
Theres no magic number when it comes to how much boost you can run. The timing and size of charger as well as drive pressures are all gona effect that.
On the 06, the smarty/tst stack aint a great idea on a stock turbo, I know, Ive ran it. But IMO I wouldnt take that stock charger much over 40 if you can help it, but 45 every now and then prob will be ok for a while.
With studs you can run more boost, but again, how much is gona depend on what charger/chargers you are running at the time.
dieselcarpenter
Mar 26, 2014 05:43 AM
dodgediesel
ABDTR #5
Oct 18, 2011 09:22 PM
dodgediesel
ABDTR #5
496
Oct 16, 2011 04:33 PM
Sinbadd
Jan 21, 2008 10:49 AM
codystroh
16
Jun 11, 2004 06:04 AM
