Twins and boost questions
I'll be installing my IdahoCTD twin turbos next week since i finally broke the bank and got a built tranny, if i remember right these make about 60PSI, how much have stock head gasgets on the 06's been holding before they blow? If i baby it(keeping my boost below a certain amount?) untill i can afford head studs and fire rings should i be ok?
I am running 55psi with my silver bullet. I have studs with a stock gasket. I would just install some arp studs and you should be fine at 60 psi provided the engine is fully warmed up prior to beating on it. Tim
Well I have my II SPS66 wastegate set at 55psi and I have seen it a number of times at the track with stock head bolts and gasket. I am waiting for money to do studs, intectors, etc. before I start beating hard on it again though.
dodgediesel
17
Apr 5, 2011 11:21 AM
Stock 02
28
Sep 24, 2006 11:09 AM
BigDan
Jan 16, 2006 05:02 PM
