turbo vs intercooler
If my egt's are too high when I tow, what should I do? It seems that the intercoolers cost about the same as the turbo's. Do they both cool the same amount? Does the intercooler give any power or just the turbo? i will be doing a little towing in a week or so, and I will find out if egt's are really a problem or not, but since I moved the probe to the manifold from after the turbo, I was very surprised at how high it gets just driving around empty.
you are not really going to gain much from an aftermarket intercooler. temps might go down a little but not enough to warrant buying one. a turbo, you would gain HP and temp would be cooler, but then you would have to worry about your tranny, its enough to warrant spending the dough for if you plan on upgrading the trans, but for half the price, you could get a water spray kit and your temps would go down a lot too, HP wouldnt change much tho unless you throw in some meth. JMHO
Jman,
The Edge makes a lots of heat and not as much power as a Smarty.
Loose the Edge gets my vote.
The stock turbo is pretty small.....You'll see your best egt reductions there.
Leave the intercooler for down the road.
The only way a diesel can make more power is with more fuel.
I would save the 600 dollars and buy a turbo. I know Smarty is a good programmer but he would benefit more from a new turbo. Even if he does get a Smarty eventually he would have to get a turbo. The edge Hot juice and Smarty both are enough to be out of the stock turbo's effiency range. Even the regular juice you would benefit more from a turbo then just buying another programmer. How much do you tow and is it on a rugular basis. I would say you would be good going with a small 62 14.
turbo for sure,my cooler didn't do anything, what a waste of money.and a poor fit, everything is tight,wish i never did it, too lazy to take it out though,took too long fighting with it to get it in. i kinda said the same thing about the first turbo too, but once you have done one, you learn the ropes pretty fast.bigger difference in the turbo.
92smokin blacky
01-14-2010 09:23 AM
6Stix
02-13-2009 08:32 AM
mullishacrew
10-30-2008 09:29 PM
CrazyKracka
08-09-2004 10:16 PM
