Turbo drop on 2004.5
Old Feb 4, 2006 | 07:15 AM
koogala's Avatar
I want to install pyro on 2004.5. I have read about both popular methods
1) the grease,magnet, & start engine just before breaking thru method
2) the loosen turbo & use a piece of cardboard method
Question.
How hard is it to drop turbo 1" for the cardboard trick? I read about a paticularly bad nut to reach on the bottom. I think maybe that was on
an earlier gen.? don't know.
Also, will I be able to re-use gaskets? I read a few threads last nite where
lots of guys re-used the same gaskets without any problems.
I need some "Been There,Done That" help. Thanks!
Old Feb 4, 2006 | 08:58 AM
Billy Ram's Avatar
If you drill in the runner by the #3 cylinder you can get most of the shavings out with a magnet. The small particles will get by the turbine ok.
If you want to drill above the flange on the back three runner I would drop the turbo. You will need a right angle drill to do this. No problem using the gaskit again. The front back nut is a bit hard to reach and you will need a 15mm deep offset boxed end wrench. The turbo nuts can be tight. I would remove the tire and splash shield and the drain tube. After removing the turbo nuts pry the turbo down enough to get a piece of cardboard in and drill away.
Old Feb 4, 2006 | 09:15 AM
Jeff K's Avatar
Duct tape over your tailpipe and do it with the truck running. The back pressure will blow the shavings out so wear safety glasses. Done this with a couple trucks and it works really well. Takes less than 10 minutes
Old Feb 4, 2006 | 09:40 AM
PourinDiesel's Avatar
Just do the magnet method you'll get more than you want out of the hole.
Old Feb 4, 2006 | 02:52 PM
bekim's Avatar
Yup! And wear some eye protection. Don't get fragged by blowing bits of metal!!
Bekim
Old Feb 4, 2006 | 04:28 PM
TST's website has an excellent set of instructions for pyro install.
http://www.tstproducts.com/pdffiles/...05Ramcopy1.pdf
Old Feb 4, 2006 | 08:33 PM
BlueDually's Avatar
did mine with the exhaust brake on, filings came screaming out like buckshot
Ron R
Sep 16, 2008 11:09 AM
West Coast
Sep 20, 2007 11:19 PM
bmallen
Feb 29, 2004 10:30 PM
shortround
Feb 28, 2004 12:06 PM
Huntindad
Feb 9, 2004 06:45 AM
