Turbo Advice
Turbo Advice
Hey guys, finally getting around to upgrading the turbo. i have smarty, airdog 165 and full billet suncoast tranny. Looking for something really reliable and putting down somewhere around 600hp...would like to keep stock injectors if i can...thanks in advance for your opinions/advice.
Talk to John @Majestic Turbo here in Waco. 254-757-3759...he is very thorough when trying to find what you are looking for power wise. He will give you every option he has available and the prices are extremely reasonable. I upgraded to a 62/65 for $1200!!! It is very quick spooling and makes power on up into the higher rpm range. If you have anymore questions shoot me a pm and I'll try to answer your needs.
i called industrial injection and they recommend the Sliver 62...says it's good to 650hp and can be used in a twin setup if wanted. I believe it's 62/80 or the Thunder 330 but he said it would be laggy...
I'll give majestic a call..thanks guys!
I finally ended up with a HTT 62/71/13ss for my turbo with future plans to use it in twins if I wanted. My numbers and mods are in my sig. I have a stock CP3 and injectors. Good luck.
staarma,
your dyno numbers are very close to what i want to achieve. Looks like the only extras you have that i don't are a big line kit and the edge hot. i have an air dog and Smarty POD...thinking maybe i should try to find a Van aken to stack with smarty..i want to keep my stock sticks as long as possible.
I honestly don't think the Silver 62 is DRIVEABLE up to 650 hp. I have one, and even with Flux 2s, Helix 2 and many air flow mods, it still is laggy, smokey, and not very forgiving. I will say that once it lights, it hits pretty hard, but you have to drive it for a while and learn its qwerks to keep from blacking out the road.
That's one reason I've kept my hot juice after all these years. I can turn it down on the fly and not smoke at all. The EZ with pressure and a little timing from the Smarty Jr. are all I need for spool with my 6 speed. When someone gets cute or I'm towing it goes right to level 6.
staarma,
C*&p!
dodgemaniac
Competition / Pulls / OffRoad
Jul 31, 2008 10:15 AM
ryan466
Aug 30, 2006 10:10 AM
2broke2smoke
45
Jan 26, 2004 03:59 PM
Hawkeye
13
Sep 17, 2003 11:04 AM
