Tst R49ap
Tst R49ap
Have my TST on the way, should be here today or Monday. What time frame am I looking at for the install? Where have you guys been mounting the monitor? Any pics? Thanks for the heads up.
It took me at least an hour to get all the wiring harnesses connected and tie wrapped. And I had installed and uninstalled 5 other boxes numerous times. Cam shaft sensor and crank shaft sensor were no fun for me laying on the ground. Then another 20 minutes to route the R49 remote wiring through my firewall access and to the dash. I already had a pyro sensor installed for my HOT Juice, so I was able to just swap sensors. That was the easy part for me, so depending on if you need to drill and tap for TST pyro sensor add time for that.
I used a Pro Fit International Unimount to locate the R49 remote where I wanted it. Here are pics of my mount.
OK, thanks! Install looks good on your truck. I have the Autometer pyro, boost, and fuel pressure, so the pyro is there already, BUT, I will probaly run both. Man, I am hoping this sucker comes on Monday, I am chomping at the bit for more power
SSminnow
25
01-18-2007 09:41 AM
WhiteSport600
12-23-2004 09:59 AM
BCobb
07-11-2004 01:49 PM
Zino
08-15-2003 10:14 PM
