TST installed
TST installed
I have the 04.5CTD QC dually with the 6spd. barely has 10K miles and installed the TST.
4-2 on the hwy in 6th gear clutch slips... but when on 6-4 I can speed shift 1st-4th w/o any slipping!!!
does anyone know why in 6th gear only on 4-2 setting why my clutch slips momentarily and then grips back???
thx guys!!!
BTW this truck feels like a MONSTER now!!!
And why does TST limit the boost reading to only 40psi. They should've designed their system to NOT read the stock boost reading and instead made an external line that taps into the vacuum lines to read boost independent of the stock boost reading!!!
thx guys!!!
I have the same truck, have the guageless TST about a month now,
mine seems to run out of fuel at 3-3 at wide open throttle, kind of stutters and unconsistant black smoke, think it just needs FASS, yours doesn't BLKHO600
at 2-2 pulls 14000pds incredibly well, got up to 1200 deg pre
not balsy enough to kept above 2-2 yet
1-0 great for mileage with the pig 600s, got about 19 US, hand figured
Hey BlueDually check your fuel filter. Mine was doing the same thing where you get the fuel surge . My pressure would drop to 4 psi when I dropped the hammer . I changed out my filter and all was good on 3 x 3. Now it hovers around mid 5.
mjpalmer
May 19, 2005 11:34 AM
WhiteSport600
Dec 23, 2004 09:59 AM
BCobb
Jul 11, 2004 01:49 PM
Zino
Aug 15, 2003 10:14 PM
