Trouble code P1932
Old Feb 17, 2006 | 06:03 PM
SORTAFAST's Avatar
Trouble code P1932
I have a 2004.5 Dodge Cummins with a Triple Dog downloader. I was checking the trouble codes and it had a P1932. Does anybody know what this means? Any help would be appreciated. Thanks!
Old Feb 17, 2006 | 08:28 PM
RamWheelsBy4's Avatar
Are you sure that is the right code number. It does not show up in my database as a DC or Dodge Trouble Code. This is all I have for that code.
P1932 Ford Fuel Additive Pump Control Circuit Performance
P1932 Mazda Fuel Additive Level Low
Old Feb 17, 2006 | 09:26 PM
SORTAFAST's Avatar
P1932 is the code that showed up on the Bully Dog downloader. That is all that I really have to go by. Maybe it is nothing. Thanks!
Old Feb 18, 2006 | 08:57 AM
If you use the key to check for trouble codes, does P1932 display on the OD readout???
To check for Trouble Codes without the BDDL, turn key from off to on three times without starting. Leave in on position, any trouble codes will display one at a time on the Odometer read out.
Old Feb 18, 2006 | 10:29 AM
SORTAFAST's Avatar
I haven't checked by turning the key on yet. I'll give that a shot and see what happens. Thanks again.
Old Dec 27, 2006 | 08:59 PM
moparmatt's Avatar
i have the same problem does anyone know what that code is yet?
Old Dec 27, 2006 | 09:08 PM
Totallyrad's Avatar
Just thinking out loud here, but, I saw a thread here in the last 24 hours that someone put up stating the triple dog would work on Dodge, Ford and Chevy, hence the name, triple dog. If that is correct, is it possible when you installed/removed the down load you may have hit the Ford button? I don't know, like I said, just thinking out loud. Rick
Old Dec 28, 2006 | 11:37 AM
Bud Kunz's Avatar
check out the list of DTCs on bullydog's web site. It doesn't have the particular code your looking for but it gets close. It looks like the other p19XX codes are all tranny codes. I'd say something to do with the transmission.
http://www.bullydog.com/media/Troubl...efinitions.pdf
Old Dec 28, 2006 | 12:07 PM
Bud Kunz's Avatar
ok I found a web site with this code listed, but it's in german so I had to translate the code.
P1932 data bus drive implausible message of Steuerg.f.Zugang and Startber.
Obviously something lost in translation, but to me it looks like it got an implausible message on the Powertrain Control Module data bus. Will the code clear?
ridlangus123
Dec 30, 2013 08:36 PM
RedRacer44
Oct 14, 2010 08:22 PM
Redliner
Dec 23, 2008 09:07 AM
sawboywv1
Jan 5, 2004 04:42 PM
dansdodgediesel
Jan 2, 2004 04:30 PM
