triple Dog and 06 Trucks
Are you guys running the TD d/l on your 06 trucks getting any codes at all? I used to get a skim key code on my 03 that I couldn't clear. I haven't installed the triple dog programming yet on the new truck and just wondered how well they are working on 06 trucks.
Thanks
Thanks
had one code...P0513 which is Incorrect Immobilizer Key...but that was kind of my fault after rushing an istall back on my truck after letting my buddy borrow it...but called bully dog and they fixed it in about 15 min over the phone...i was very happy...other than that no problems...Jason
Well I loaded it and all works but it set a P2509 code which is low or intermittent voltage to the ecm. I'm not real concerned about that as the CEL went off after 4 key starts, but the code still shows using the key method and the bullydog doesn't see it to clear it. Any ideas?
It must not be much if the downloader can't find it to clear it. But to be safe, call bd and I'm sure they will walk you through it. Other than that. Did you get to try it out? I sure liked it on my 06 untill I sold it.
Why did you sell yours if you liked it goose2?
I used the outlook monitor , went to the dtc screen, it did not show any numerical codes but asked if I wanted to clear all codes. I did and the code is gone. Thanks.
Still waiting for Bullydog to call me back
I had a similar problem when I bought mine and first loaded it, except I had several codes and the CEL and airbag lights came on. I had an older software version and didn't realize it. Had dealer reflash my computer and then reloaded latest version and all has been well for the last 10K.
