transmission temperature
Old Nov 13, 2004 | 11:44 PM
OOPS's Avatar
What type of transmission temperatures should I see after driving fifteen miles, unloaded on the freeway. I just installed my gauge and it bearly moves off of 140.
Old Nov 14, 2004 | 05:01 AM
LRod's Avatar
I'm using an X-Monitor and get about the same reading. Depends on where you are and the outside temperature. I just went 2700 miles hauling a 40' 5th wheel trailer and never got about 160. You can add about 20 degrees to whatever reading you have to be safe.
Old Nov 14, 2004 | 08:06 AM
Blue600's Avatar
Going to work (all downhill 12.5 miles) mine never comes off the 100* mark. Going home it will hit about 110*.
Old Nov 14, 2004 | 10:59 AM
OOPS's Avatar
Thanks, I though I would see higher temps then that!!
Old Nov 14, 2004 | 11:33 AM
ratsun's Avatar
Where are you taking the temp from, the oil line going to the cooler or the pan? From the outlet line the gauge will show rapid changes from lock up to unlock.
From the outlet line mine reads 160 rolling down the freeway in lockup but we dont have the same trucks or gauges so there will be some differance. I expect things will change after I remove the heat exchanger to make room for the twins Good goin on the install you wont regret it
Old Nov 14, 2004 | 12:57 PM
Blue600's Avatar
My sender is in the outlet line. Yes I can see a difference from lock up.
Old Nov 14, 2004 | 01:32 PM
Shovelhead's Avatar
Administrator / Scooter Bum
I realize we have different trannys. Just for comparison.
I see around 180* in slow traffic with outside temps above 50 or so degrees.
Can get higher when towing in summer traffic.
When driving straight highway, depending on outside temps (50s and below), the gauge won't move off of 140, because of lockup.
Sender is located in Hot Line, before heat exchanger.
Old Nov 14, 2004 | 07:41 PM
PapaSmurf's Avatar
Hello
I have the sensor "T" ed in the hot line about 6 inches fron where it comes out of the trans. It barly moves off the peg on the gauge. When pulling the 5er in stop and go and when backing up the gauge reads much higher. 160/200 is not hard to reach.
Once the truck is in "lock up " mode the convertor is locked and so it is not creating any heat. The heat comes before the convertor locks.
Just my 2 cents worth.
See Ya
Chris
Old Nov 14, 2004 | 11:50 PM
OOPS's Avatar
It is mounted in the "Hot" tranny line. I bought the line from MassDiesel!!!
Old Nov 15, 2004 | 03:10 PM
OOPS's Avatar
Being a total rookie when it comes to automatic tranmissions, what is "lock-up" and when does it happen?
Old Nov 16, 2004 | 07:38 AM
Blue600's Avatar
The torque convertor locks up its clutches at 49mph and unlocks at 45mph. That's the best way I can describe it, I'm new to these automatics too.
dogfish
Nov 14, 2009 10:03 PM
.boB
May 3, 2009 09:23 PM
dspoon
Apr 13, 2008 10:29 PM
DennisB
Oct 28, 2005 09:04 PM
John H
Jul 5, 2005 09:26 PM
