Totally adjustable boost.... How?
Old Jan 25, 2007 | 10:47 AM
trik396's Avatar
I'm going to be going with either a larger turbo (Silver62) or ArcticAir compound turbo setup this spring hopefully. Is there a controller/box/programmer where I can adjust boost in cab easily (with a **** or something)??? Don't know if I want to have to adjust at the wastegate with an adjustment nut... I want to keep boost at 40psi initially. I still have stock PLASTIC intercooler. I want to keep egt's down as much as possible, obviously. I will get aftermarket intercooler and studs in the future. Any opinions and options will be appreciated. Thanks...
Old Jan 25, 2007 | 10:57 AM
morkable's Avatar
on the 6280 there is a elbow that comes out of the front of the turbo, in that elbow there is a little allen screw, the more you turn that in the more boost you get. Dont worry you wont be over 40 by much with just the predator. You have to have a lot of fuel to get it into the 50's. When I shut the edge off and just run on the pred I usually hit about 44psi, and that is with the screw turned all the way up
Kevin
Hdog
Oct 27, 2014 10:52 AM
77machomopar
20
Dec 11, 2009 10:37 AM
stutz
38
Feb 23, 2005 11:14 AM
Mudcat
Oct 14, 2003 03:36 PM
