tone ring mod w/ tst
I just installed a TST and had done the Tone Ring mod prior. Before I installed the TST I adjusted the ring back to stock just to be on the safe side. The TST is pretty agressive with the timing and does not need any help(additional timing).
I too have done the tone ring mod and run the TST, it is too much if the ring is advanced to the bolts. It threw a cam/crank out of sync code, and rattled pretty bad even with the TST on 0/0. I backed it off about 1/2 way and no code since. it doesn't rattle as bad but I think I need to put it back to stock,(just hard to give up the increase in mileage).
Dodgezilla
04-03-2006 02:09 PM
BossHogg
09-30-2005 06:31 PM
Dodgezilla
09-30-2005 12:56 PM
BossHogg
09-14-2005 09:48 AM
