tired of cracking code...?
so, every one out there is probably aware that the cummins code is a little tough to crack to say the least....
and for those that have cracked portions of it, theres obvious limitations....
so......
im thinking that theres a market out there for stand alone ecms...
im thinking that to make worthwhile, it needs to be LOADED!
multiple injection event capability ( 1-5 per cycle )
atleast 5k rpm capability
fully tunable timing maps
fully tuneable presure maps (30kpsi+ once sensors are worked out )
fully tunable boost maps ( 10 bar enough?)
3d and spreadsheet type tables
so while in the process of brainstorming....
what if you could get fuel delivery maps for the injectors ?
that way you can use that info to compare deliver based on presure and duration?
what if those maps were loadable into the ecm to help with tuneing?
......... yep.... bright future ahead.......
so......
Well Bosch has had one for a while, works with any CR engine I think. You are on your own with programming it seems. A little expensive to play with programming. Probably blow up a few engines before you get anything close to what you want.
http://www.bosch-motorsport.com/pdf/...el/MS_15.1.pdf
High_Velocity
Dec 1, 2003 09:03 PM
Max
Mar 7, 2003 12:03 AM
