Block cracking number
Old Jan 9, 2003 | 11:47 AM
Campin Johny's Avatar
I searched but couldn't find the information I saw on this sight previously. Was it the #53 blocks that were prone to cracking? Need to know, ready to make an offer on a truck. Thanks John
Old Jan 9, 2003 | 12:01 PM
nascar mark's Avatar
Re:Block cracking number
Thats correct. #53 cast in block under inj pump, right above pan.
Old Jan 9, 2003 | 04:11 PM
Pit Bull's Avatar
If there is not a 53 or 54 etc and instead several small numbers/letters that are hard to read, then it is a Mexican Block which is great they are the strongest blocks made by Cummins and seem to be made of harder material.
Old Jan 9, 2003 | 04:31 PM
DEZLPWR's Avatar
Even if it is a 53 block truck that you are looking to buy, it shouldn't be a deal breaker! 53 block failures are still VERY rare. Go buy the truck and then stop and get a lotto ticket. You have a better chance of winning the lotto than you do getting a cracked block!
Old Jan 9, 2003 | 06:25 PM
Thanks for the input. Now I'm just waiting for the salesbabe to call me back. John
Old Jan 10, 2003 | 11:33 PM
Haulin_in_Dixie's Avatar
Darn, mine cracked.... and I forgot to buy a Lotto ticket
Old Jan 11, 2003 | 12:55 AM
DEZLPWR's Avatar
[quote author=Haulin in Dixie link=board=5;threadid=9428;start=0#90891 date=1042263201]<br>Darn, mine cracked.... and I forgot to buy a Lotto ticket <br>[/quote]<br><br>How many miles did you have on it when it cracked?
Old Jan 11, 2003 | 03:32 AM
Dezlpwr it had right at 60,000 when it started losing coolant. It cracked due to heavy use which is a symptom of the weak blocks. They crack near the turbo, a verticle crack that leaks to the outside, no internal leaks.
Old Jan 11, 2003 | 07:36 AM
Pit Bull's Avatar
[quote author=Haulin in Dixie link=board=5;threadid=9428;start=0#90911 date=1042277578]<br>Dezlpwr it had right at 60,000 when it started losing coolant. It cracked due to heavy use which is a symptom of the weak blocks. They crack near the turbo, a verticle crack that leaks to the outside, no internal leaks.<br>[/quote]<br><br>So you got a new short block under warranty at 60K miles. That is kinda like winning the Lottery
Old Jan 11, 2003 | 07:37 AM
Pit Bull's Avatar
What block number did they replace it with?
Old Jan 11, 2003 | 01:48 PM
lksamm's Avatar
Cracked Block #53
I just got back from heading up the pass and smelled antifreeze and guess what? There is a 12-14&quot; horizontal crack just under the turbo. You guessed again block #53.
Old Jan 11, 2003 | 03:04 PM
DEZLPWR's Avatar
Re:Cracked Block #53
[quote author=lksamm link=board=4;threadid=9428;start=0#91007 date=1042314535]<br>I just got back from heading up the pass and smelled antifreeze and guess what? There is a 12-14&quot; horizontal crack just under the turbo. You guessed again block #53, 67900 miles. Will they warranty this? I have a BD comp box, gauges and a pressure lock. What should I do!!!<br>[/quote]<br><br><br> <br>That sucks lksamm! :'( :'(<br>Do you tow? If so, how heavy?
Old Jan 11, 2003 | 03:13 PM
muddymess's Avatar
[quote author=lksamm link=board=4;threadid=9428;start=0#91007 date=1042314535]<br>I just got back from heading up the pass and smelled antifreeze and guess what? There is a 12-14&quot; horizontal crack just under the turbo. You guessed again block #53, 67900 miles. Will they warranty this? I have a BD comp box, gauges and a pressure lock. What should I do!!!<br>[/quote]<br>if u still undr wrrnty, take it in after u remove the box,and the velcro and the sticky from the velcro. the suckaz wld try to blame it on the box although we all know it is a design prob with the block. if ya had different injectrs,,remove em too.<br><br>what yr is u rig<br><br>good luck<br><br>
Old Jan 11, 2003 | 03:51 PM
PourinDiesel's Avatar
Take your power box off,<br>then take it to a Dodge dealer.<br>Its not your fault the block cracked.<br><br>Your Cummins warranty specifically states that the Engine block and all internals are covered.<br><br>--Justin
Old Jan 11, 2003 | 03:58 PM
Tom's Avatar
Tom
All I can find on mine is a 56. This truck is an 02 manufactured in July, and it was made in Mexico. Is the 56 one of the Cummins blocks shipped to Mexico? Just curious, but what makes one block stonger then the other. Was there a manufacturing mistake or what?
